HI guys.......
Can anybody tell me what the major differences are between the Firestorm and the SP - particularly from an engine point of vew?
Also what are the main differences between SP1 and SP2??
FIRESTORM v SP
FIRESTORM v SP
She's my idea of beauty and thats what I ride.
Aside from the SP being injected, it has way more top end than the Storm. It's also a bit of a torture rack to ride all day. As for differences between the SP's, I think the injection is more sorted on the 2, and you get the improved swingarm as well. Oh yeah, and don't forget the direct ram-air setup on the SP which goes through the front of the frame.
SP1/2
The SP1 & 2 are completely different to the FireStorm and don't share any common parts at all. Capacity is 999cc rather than 996. Swing arm isn't connected to back of engine for greater rigidity etc. A track tool which Honda used to win WSB twice. If I had a dream garage I'd have one but for 95% of the time the 'Storm does everything I want to do.
I've recently bought an '04 SP2 and don't find it too uncomfortable at all, admittedly it's no tourer but it's no worse than many other current sports bikes. I've done a couple of 300 mile runs and only suffered an aching throttle wrist.
Handling can be a bit lively if you're pushing it on bumpy stuff but in general it's great.
It's very highly geared and benefits from a smaller (15t) front sprocket, or a slightly larger (42 or 43t) rear. This makes it less of a pain in town and other 30mph limits.
The fuelling can be a bit snatchy at low revs but it's not really a problem, I'm told a PCIII smooths things out somewhat but I find it OK now I'm used to it.
If you ever take a pillion the 'seat' is a joke.
PS, There's quite a bit of info on SP's on http://www.honda-forums.com and http://www.rc51.org
I just bought an 04 SP2 and found it reasonably comfortable after a few years on Ducati Monsters. As has been said it can be a pain in the wrist and at times I'd like a cruise control just to give my wrist a break other than that its a very fast road bike covers ground quickly and you can get high angles of lean without scaring yourself. Fuelling is a bit snatchy around town ( its supposed to be worse on an Sp1) and it can shake about on bumpy roads but not worryingly so, if it does spin rear up or slide it seems easy to correct.
I'm going to be taking it around Europe soon and can't foresee any major discomfort, a tank bag to lean on should solve wrist ache.
Sanity is the playground for the unimaginative
