Re-spraying wheels.
Diabolus
Re-spraying wheels.
Post by Diabolus »
What's the paint code for the black wheels ? + any tips on painting I have a friend who can get them blasted is this ok ?
http://lincsrideouts.co.uk
Re: Re-spraying wheels.
make sure you cover the bearings, do what tony does, run the spindle thru the wheel with large washers on either end, because masking tape will not protect them during blasting, as for paint code, i don't think it really matters if its a normal gloss black.
i'd go for a metallic gunmetal grey myself...... :thumbup:
As BSM said go for bog standard black if black is what you want , however if you want a dark metallic grey finish that's the same as the pre-2001 engine covers
For just £12 400ml of GCC7026 Dark Grey Metallic (with a hint of brown) ME068547BC should do the trick. Prepare surface by stripping old paint, keying with wet&dry, or alternatively sand blast > degrease, mask up and prime with etch-primer before applying layers of finish. Not sure on lacquer as they are a satin finish and most readily available lacquers are i.e. Simoniz are gloss.
For later models with the more goldy coloured covers owners might try HYCOTE vauxhall titanium pearl / halfords VAUXHALL TITANIUM SILVER
HOW-to for BMW engine covers that demonstrate the principles:
http://www.motorcycleinfo.co.uk/index.c ... eId=739661
rob's red storm
Post by rob's red storm »
I used that how-to for the engine covers on my BMW, came out a treat!
Sent from my iPhone 4 using Tapatalk
Diabolus
Post by Diabolus »
Thanks for the tips ect.... Just what I wanted.
