How much turn?
- scott02464
How much turn?
Just out of interest how much twist does a standard throttle tube have?
I put a HRC quick action tube on mine which has 1/6th of a turn.
Re: How much turn?
6 x's the amount of the HRC one ????scott02464 wrote:Just out of interest how much twist does a standard throttle tube have?
Re: How much turn?
Re: How much turn?
The standard one is 2/3 but can be made into a 1/4 buy removing the return cable . Like I did :-) and its good for me 1/6 would be mental one little bump in the road and up pops the front wheel :-) .
- scott02464
Re: How much turn?
It's not too bad tbh mate, i can tell there's deffo a difference but not enough to make any poo come out tho!lloydiecbr wrote:The standard one is 2/3 but can be made into a 1/4 buy removing the return cable . Like I did :-) and its good for me 1/6 would be mental one little bump in the road and up pops the front wheel :-) .
It's used up all my slack in the cable and managed to keep the return cable on!
Re: How much turn?
How do you do that Lloydie? Would like a quicker action but not 1/6th....lloydiecbr wrote:The standard one is 2/3 but can be made into a 1/4 buy removing the return cable . Like I did :-) and its good for me 1/6 would be mental one little bump in the road and up pops the front wheel :-) .
Standard you need to be double jointed to whack it right open. Strange, my right wrist has certainly had plenty of exercise
'02 VTR1000-FY Yellow.
- agentpineapple
Re: How much turn?
+1 on what rob said, its bloody frustrating with the standard throttle set up....
Re: How much turn?
Just remove the return cable and put it in the bin as its not needed .
Then adjust the pull cable as their will be lots of slack in it after removing the return cable .
The carb spring is huge and strong it will snap shut very fast .
Removing the return cable also makes the throttle lighter to use .
And also makes it easier to remove and refit the carbs .
If you don't like it have a dig in the bin and refit the return cable .
Re: How much turn?
you just need more bhp and a black one as they come with 100bhp standard unlike the slow blues 70bhp lolbigspanishmarty wrote:+1 on what rob said, its bloody frustrating with the standard throttle set up....
- agentpineapple
Re: How much turn?
hahahahalloydiecbr wrote:you just need more bhp and a black one as they come with 100bhp standard unlike the slow blues 70bhp lolbigspanishmarty wrote:+1 on what rob said, its bloody frustrating with the standard throttle set up....
have your fun while you can mate, the blue beastie will be back to full power soon enough.....ROOOOOAAAAARRRRRRRR!!!!!!
Re: How much turn?
And also a kawasaki er5 throttle tube is half way between the storms and a 1/6
And they are cheep I had one on mine till I broke it changing grips :-(
- scott02464
Re: How much turn?
Iv been out on it this afternoon and the throttle tube works bloody brilliant!
The full range of power is accessed so easily on the back roads but its not too much in traffic what so ever.
It's proberly one of my top 3 best mods Iv done!
- scott02464
Re: How much turn?
Ps. My blue one chucked out 103 bhp on the last dyno run. Now Iv tweaked it more it feels even stronger
Re: How much turn?
Scott, don't take the bait mate, it's Blue envy again!! Lloydies got the only two stroke storm on the forum! Well it drinks enough oil to be a stroker anyway.
- scott02464
Re: How much turn?
LolKev L wrote:Scott, don't take the bait mate, it's Blue envy again!! Lloydies got the only two stroke storm on the forum! Well it drinks enough oil to be a stroker anyway.
