Having trouble
scott02464
Having trouble
Post by scott02464 »
Dudes as you may have noticed in having trouble posting posts, I get this message and then end up posting 3-5 posts :-(
Anyone else suffering this misfortune?
Re: Having trouble
Not had any problem with my laptop or with my I Pod mate.
scott02464
Re: Having trouble
Humm, I wonder if it's do do with my signal at the time then?
Re: Having trouble
Looks like there may be a file missing from you account. Maybe it could have got corrupted or something in the switch over. I'm sure admin can sort it out now they know.
Have you tried switching the BBCode on and off from your edit posting defaults in your user control panel under Board Prefs.
scott02464
Re: Having trouble
cybercarl wrote:Looks like there may be a file missing from you account. Maybe it could have got corrupted or something in the switch over. I'm sure admin can sort it out now they know.
I'll check the bbcode now mate, I'll look at the settings on this tapatalk, although my last two post posted straight away..... Now Iv jinxed it! :lol:
scott02464
Re: Having trouble
scott02464
Re: Having trouble
scott02464
Re: Having trouble
Iv just reset the app and switched the bbcode on and off (whatever that is?)
So here goes hoped its worked :-(
scott02464
Re: Having trouble
scott02464 wrote:Iv just reset the app and switched the bbcode on and off (whatever that is?)
And to try replying to a quote....
scott02464
Re: Having trouble
scott02464
Re: Having trouble
Agh so it's when I'm replying to a quote??? :-(
Re: Having trouble
Weird, but it does seem to happen when you use quotes.
The BBCode is the coding used for the tags in posts
Code: Select all
opening tag[code]quote
note the forward slash in the closing tag[/code] :wink:
I have recently discovered another bit of tweaking that's needed since the change. When posting pics from Photobcket using the IMG code.
Code: Select all
[IMG]http://i1087.photobucket.com/albums/j476/cybercarl0/VTR1000%20forum/DSCF8020.jpg[/IMG]
like so
ImageWe have seemed to have lost the ability to click on the image to view full size. It could be a problem on the Photobucket side but seems to be a bit coincidental.
Using the IMG thumb
Code: Select all
[URL=http://s1087.photobucket.com/albums/j476/cybercarl0/VTR1000%20forum/?action=view&current=DSCF8020.jpg][IMG]http://i1087.photobucket.com/albums/j476/cybercarl0/VTR1000%20forum/th_DSCF8020.jpg[/IMG][/URL]
everything works as it should.
Re: Having trouble
Scott can you try posting a post without using the quote tags. But quote something manually like so
Code: Select all
[quote]write a test quote here[/quote
and leave off the last brace ] on the end.
Lets see what happens. Also check when your next posting if the checkbox below in the options is unchecked for BBCode
cupasoop
Re: Having trouble
Post by cupasoop »
The tapatalk problem is being looked at and the picture size issue is a mod that hasnt been reinstalled yet.
Rich.
scott02464
Re: Having trouble
cupasoop wrote:The tapatalk problem is being looked at and the picture size issue is a mod that hasnt been reinstalled yet.
Thanks cupasoop, ill just carry on as normal mate and leave it in your hands.
Sorry if its annoying to everyone seeing more than one of he same posts.
I wonder why no-one else is having this trouble with tapatalk? :x
