removed the baffles out my microns today to get more of a grunt out of them when i got them on flea bay the bloke said they were removable arrived to find there tack welded in 3 spots so as it was a bank holiday thought ill do abit of surgery on them got the air cut off tool on the 3 welds got the baffles out then i made the hole bigger with halfrauds grind stones [crap] as the air die grinder was at work so will tidy them up a little more tomo. im gonna re-use the baffle drill a hole in the end plate and baffle so can be used as removable baffles
that will make the microns louder
im worried when i die my wife will sell my bike for what i said i payed for it
Re: that will make the microns louder
Good work there .
Are you re-packing them wile you have them in bits ?
i was thinking about it but it looks like it was'nt done all that long ago
Nice I like the idea of using the baffle as a removable piece, very clever idea.
cheers mate just come back from work and god does she make a nice rumble and she is going alot better now dont know if its just the carb rubbers or a combination of both thats made the diffrence
Removing baffles will do that. Straight through can with no restrictions. You will be playing with your carbs and re-jetting nextnd she is going a lot better now
cybercarl wrote:Removing baffles will do that. Straight through can with no restrictions. You will be playing with your carbs and re-jetting nextnd she is going a lot better now
i am thinking about it i want to get a bellypan and a seat cowl for it next
