Did a bit of research but all I could find was this:-
http://www.topyokes.com/comfort_kit/197
The kit looks good and comes with everything but is £245.
Any other (cheaper
*Edit
Just noticed it's Ex. VAT - so nearer £300.
Looks awesome but HOW MUCH??? Jeesh.Rob wrote:Will probably eventually fit straight bars for comfort.
Any other (cheaper) options?
*Edit
That's the same company - just more expensive via eBay.lloydiecbr wrote:This seller will do you a top yoke to order .
Look at this on eBay:
http://bit.ly/W3Jc8j
And for bars
http://bit.ly/SsKlGa
You should still be able to use standard length throttle cables
And braided lines
The only thing you will need to make longer is the horn wires and remove a bit of the fairing
That's what I am going to try and do. The first plan is to fit a 2nd yoke over the top of the standard ones.lloydiecbr wrote: The other option is to drill the top yoke and fit bar clamps
txt sentAMCQ46 wrote:That's what I am going to try and do. The first plan is to fit a 2nd yoke over the top of the standard ones.lloydiecbr wrote: The other option is to drill the top yoke and fit bar clamps
I will have the top face milled flat and the key lock removed and the steering stem bored out to clear the top nut. Then this will be machined underneath to provide 2 positions for the bar clamps.
Then I need to workout if I use the ultra low bars like lloydie linked, or the flat ones....this conversion will already have the bars a bit higher by the thickness of the spare top yoke, so not sure what will work best.
the first one in your link wont work on the storm ,i know as i tried it .nutter_on_the_bus wrote:Has anyone tried these?
http://www.mandp.co.uk/productinfo.aspx ... Two-Wheels
or these
http://www.mandp.co.uk/productinfo/3203 ... Conversion
I know the last one is in the CNC ballpark but it does leave the original yoke in place
Simple idea but very effective. They are nicedarkember wrote:Look at the Apex range they are infinitly adaptable.
http://www.apexmfg.com/products
Checkout the Utube video to appreciate its versatility
