Why is leaked clutch fluid black?
Got a small leak from my clutch reservoir which I'll rectify soon but why is the leaking fluid black?
Re: Why is leaked clutch fluid black?
It turns black as it's been exposed to air, moisture and heat, in other words hydraulic fluid needs urgent changing. And best do brake fluid at same time.
It probably wont help your clutch slip either. Best to do a fluid change and bleed it all off.
It turns black due to the small amounts of rubber from the clutch slave cylinder seals.
Mine's the same on my Mille.
Don't know why this does not affect the brake side. Try new seals / master cylinder repair kit if it bothers you or just change the fluid more regularly.
Doing regular top ups at the moment but it needs a seal kit as soon as I have the time and money.
