Backfire in air box?!
Benno_0214
Post by Benno_0214 »
Hi everyone!
I have recently bought myself a storm, I'm loving it! Just a quick question really, is it common for the bike to pop and backfire into the air box? Mine seems to do it every once in a while at very low revs, and sometimes cuts out :?
A guy I work with had a storm years ago when they first came out, he seems to remember his did the same?
It's a totally standard bike, runs really well apart from this occasional air box fart!
Any help would be apprieciated!
Cheers Ben
Did you just high five me in the face?!?
Re: Backfire in air box?!
Greetings
'carb fart' perfectly normal - just raise the idle a notch to lessen the chance of it stalling in a tight corner.
Post some pics of your bean eatin' storm beasty.
Benno_0214
Hey!
Phew that's good news! worries me everytime it does that!
Il get a pic posted up ASAP!
:D
Cheers!
Phimosis
Post by Phimosis »
If your wearing thin jeans, which you shouldnt you can feel the warmth of the fart in your crotch area :eek2
She told me she was 16.
scott02464
Post by scott02464 »
If you get the carbs sync mate it helps a lot and doesn't do it quite as often.
lumpyv
Post by lumpyv »
if its standard have a think about the cct,s and the reg/ rec, its all on here how to sort them out
:thumbup: :beer: :thumbup:
Benno_0214
Cheers for the advice! I'm gonna take a look at the cct etc soon, didn't realise until I looked on here that they had this issue. Better safe than sorry tho!
Ben
If you going to be doing you CCT's then it's the perfect opportunity to fit a front cylinder vaccum take off for carb syncing http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18430 and do a carb sync. :thumbup:
Xenocide
Post by Xenocide »
Yep mine does it all the time - pain in the butt isn't it? :(
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Having the carbs set a tad rich helps to stop it to
rollingthunderx2
Post by rollingthunderx2 »
Mine does that, its common. This helps tho.
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=25801
You seem to like posting links :lol: It's good that your reading all these threads but if you read that thread all the way through you would realise that that came down to a carb balance as well. Yes TPS does help but it could just as well be a simple carb balance that will sort it out.
IMHO I think it generally comes down to the bike needed a good tune up. This could mean altering a few things. Remove carbs and give them a clean, check the jetting and mixture setting, while carbs are off adjust the TPS, also while carbs are off fit a front vacuum take off for carb balance simplicity. Re-fit carbs and balance them. Warm bike up to running temp and get the mixture spot on, then maybe another carb balnce.
Or just turn the idle speed up a tad and forget about it. :lol:
The worse it is the more attention the carbs need as Carl said
