any one on the cb1000 fourm
thumperslaw
Post by thumperslaw »
Any one can post wanted things in there?
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
lanny
Re: any one on the cb1000 fourm
Post by lanny »
Re: Regulator Rectifier issue
it seats near the battery (remove the riders seat).
First things first...the simptoms you describe are of a battery gone flat or internal cell error...check the battery on a battery cheker to see if it is good or bad...then if it is good check the charge (it should be anywhere between 13,2-14,9 (some suzukis ewen 15,2 volts))...upon cheking ewerything, check your generator (pull the regulator conector and cross messure the 3 windings on the generator plug...it should read 1,0-1,3 ohms between them)...allso check the 3 windings for shortage to the gound/chassis (turn on the peepser on your meter)...
Next let us know what you have got.
AND...if your battery is bad get a new one as your readings with bad battery are going to be off !
lanny
Post by lanny »
This is on the Fireblade forum so i'm not to sure if the same as the CB1r, but i'm sure Wheeler will know.
There are 3 ways to check the stator
1. A continuity test on all the 3 yellow wires from the stator
2. AC Voltage test use a multimeter then set dial to 600vac, Run engine and test each yellow wire with earth readings up to 70-75 volts per phase, if not suspect is the stator.
3. Remove the alternator cover for a visual check in all probability you would see the damage done its a 99% certainty.
lanny
Post by lanny »
Hope the stators not F****d, link attached if so. Cheaper than oem :thumbup:
http://www.electrexworld.co.uk
thumperslaw
I think it is the rec thats gone fubar
They don't seem to be cheap tho
K100 "flying brick"
thumperslaw
lanny wrote:Hope the stators not F****d, link attached if so. Cheaper than oem :thumbup:
Already looked on there and can't seem to find one for his bike
K100 "flying brick"
StormingHonda
Post by StormingHonda »
You can get them repaired for about £90. But it means you go without a bike for a few days or up to a week.
thumperslaw
Rather tell him to get new
Last one only lasted two years The bike was brand new
K100 "flying brick"
No? Me neither.
StormingHonda
I had no problems and niether did the next owner of the bike I had done, brand news always going to be better for sure tho.
