Powercoat or paint???
- bigtwinthing
Hi i plan to have my wheels done before the nice weather comes, do i powdercoat or paint? i will probably do them silver. Any preferences anyone?
Regards Paul.
Regards Paul.
- agentpineapple
Re: Powercoat or paint???
its a 50/50 tbh
powder coating will bake the wheels so i would assume a harder finish, but a good painter and time to cure and i doubt you'll have any problems with that either, painting gives you a much wider choice of colours, but seen as you want silver, that ain't really a problem. i've painted a few wheels myself and achieved a pretty decent level of finish. personally i'd probably choose p/c because the wheel will be blasted first, so the finish should be spot on, i reckon you'd have to take the bearings out tho, i'm sure someone will correct me if i'm wrong, and i usualy am.......
You can leave the bearings in if you put a bolt through with large enough washers on, so that they cover the bearing surface, but why not just put in new ones anyway, while it's off the bike?
ive painted loads of wheels (properly) and ive powdercoated loads of wheels
powdercoat ,
powdercoat ,
its not the dog in the fight its the fight in the dog
powdercoat much longer lasting finish
- BigVeeGrin
What if you want bare metal - are they lacquered/protected by a clear process?
you can get clear powder coat
seen it on a few bikes and it ties in well with the ali frame
- BigVeeGrin
cheers Lloydie - out of interest what could I expect to pay for a couple of wheels?
- bluestoesonnose
Done both more times than I can remember, I always paint now.
There are many, many, many arguments for both, but if you chip a powder coated wheel (and they do chip) it'll be a nightmare to get it redone as you have to remove the coating, with paint you can get it done in a day or two, modern paints are very, very good, chap here in Plymouth does it so cheap I feel I'm ripping him off every time I get a wheel done.
Up to £50 a wheel :-(BigVeeGrin wrote:cheers Lloydie - out of interest what could I expect to pay for a couple of wheels?
Shop around to find the best place locally .
It worth wile asking in your local bike shop to .
- BigVeeGrin
got a wheel refurbisher a few hundred metres away so going to pop in and see silver examples of bike wheels done before. Local bike shop is the honda dealer and they are as helpful as a {insert example of very unhelpful thing}
Why would you want you wheels clear coated. Why not use a good quality detailing product like Armourlite or a Ceramic shield. A Ceramic shield bonds itself into to the paint molecules and is as hard if not harder than paint. Speak to Chric for some advice on a good product to use. It will be loads cheaper than powdercoating.
- BigVeeGrin
I reckon silver metal wheels would look neat on a black storm with red detailing (decals and maybe calipers and red belly pan). But then my skills at design etc may be wanting. My back wheel I got from Marty is part silver already and does look good, so I thought I'd go the whole hog.cybercarl wrote:Why would you want you wheels clear coated. Why not use a good quality detailing product like Armourlite or a Ceramic shield. A Ceramic shield bonds itself into to the paint molecules and is as hard if not harder than paint. Speak to Chric for some advice on a good product to use. It will be loads cheaper than powdercoating.![]()
- thumperslaw
motostorm wrote:ive painted loads of wheels (properly) and ive powdercoated loads of wheels
powdercoat ,
+1
Getting mine power coated couple of weeks
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
- bigtwinthing
thanks guys, Silver paint it going to be, blasted first and painted, had a quote £95.00 all in bargain i will show you the pics after there back on after the all important live saving ski trip!. Remember "crash but learn" !!! :
