headscratcher for the boffins :D
- benny hedges
interesting fault on a machine today..... 3 people have looked at it before and made it worse lol!
this is how i found it.
the wiring was nice and neat when it left the factory but now looks like a bird's nest!
what happens is when i press the start (reset) button, 2 led's light up on the control pcb A1F to say there are no faults.... but it wont start, until i manually press in relay K1M with a screwy.
the relay then latches and the machine runs normally, until its idle function kicks in, then it stops automatically, with the led's still lit, saying there are no faults, but it wont restart until i again manually press in the contactor K1M.
apparently theyve been starting it like that for years!
it appears someone in the past has got confused by the wiring diagram and thought that the contactor on the right is K3M - when it's actually K1M. (thats a clue to the fault btw!)
i know what the faut is btw... just seeing if anyone can suss it
Re: headscratcher for the boffins :D
sprockets caught int treadwheel.
I don't come on here asking you difficult questions about buried telephone cables! whats going on?
presumably the internal wiring is correct as it would have been factory tested so the fault is with the incoming feed
- benny hedges
no mate, it's been systematically fuxored by a succession of numptys who have missed the original fault and bodged it to get it going!playerone wrote:presumably the internal wiring is correct as it would have been factory tested so the fault is with the incoming feed
externally its bob on - looks brand new.
it's the wiring that's been cabbaged.
- bigtwinthing
who cares it aint a bike!!!
check the coil on MK1
check the control coil in K1m
just in case you didnt do it first time
defo the control side of the contactor, maybe to a relay or a trip of some kind, keep hunting and it shall appear but defo control
- benny hedges
nope - its fine cos it latches when you press it manually ;)edds11 wrote:check the control coil in K1m
ive already fixed it btw - just seeing if anyone spots the fault....
what is it?
Fuse, or not switched on.
Or was it a loose battery connector like the SP2
- benny hedges
ahahah basterd lol! no, its not a fuse ;)AMCQ46 wrote:Fuse, or not switched on.
Is it somehow that the coil for k1M has been mistakenly wired so that it is being latched in by a contact from itself (ie it would never latch in unless manually forced to energise ie the screwdriver). should be latched in by a contact from K3M ?
