high rise exhausts
high rise exhausts
Hi all. Does anybody have any idea where i can get a set of high rise exhausts from? And is it just riser pipes I need or is it full set of new cans as well? Because I want to keep the fuel stubbies that I have fitted but I have always had a thing for high rise pipes. Any info on what I would need to buy and to fit would be most grateful ta
Re: high rise exhausts
Keep an eye on flea-bay, Sales & Wants section here, or see if an exhaust fabricator can knock-up some hi-level link pipes.
Bear in mind that you might need to fiddle with carb settings to the change in exhaust dynamics.
You can always enlarge the diameter of pipes or use stepped converters. Or just get one made up.And is it just riser pipes I need or is it full set of new cans as well? Because I want to keep the fuel stubbies
http://www.ebay.co.uk/itm/Exhaust-Tail- ... 5ae58a51e7
http://www.ebay.co.uk/itm/Exhaust-Reduc ... 1c1a82f70f
Or you could even make up your own custom pipe.
http://www.ebay.co.uk/sch/i.html?_nkw=e ... &_from=R40
