Clocks
Clocks
Speedo/Rev counter unit, should it have a covered back, I recently had the fairing off and realised I could see the PCB etc inside the clocks, is that how they should be or am I missing a back cover. Just seemed a bit open to the elements, I know it's behind the headlight and fairing but i'm sure water could get in there without too much effort.
Re: Clocks
The backing to the clocks is a white cream colour is that what you can see with lots of wires
Re: Clocks
it stays dry in there unless you drop it in a puddle / river or get a bit overzealous with the hosepipe come cleaning time
Re: Clocks
Yep, just thought I might be missing a back cover, won't worry about it then,thanks.lloydie wrote:The backing to the clocks is a white cream colour is that what you can see with lots of wires
- agentpineapple
Re: Clocks
as seb said, just be careful when washing the bike, otherwise it's ok, if you have an aftermarket clear screen (normally the cheap ones) it looks bad because the back of the clocks is on show, thats why hondas original screen has the lower part darkened to hide the rear of the clocks....
