hi all,could someone help,got ready to go on my maiden voyage today,put some air in rear tyre and valve blew out.(gutted)
need to remove back wheel,but will the bike be stable if i jack up on the sump?
cheers guitarman
rear wheel removal
Re: rear wheel removal
Better off using the Abba Stand which will lift the rear wheel off the ground. If you dont have one of those then hanging the rear end off a solid beam. Block & tackle with a wide strap to do the lifting.
hi
what is your location? someone nearby may be able to help you.
a basic paddock stand will be enough for you, unless you have better equipment.
richard
richard
- Saintsman27
Yep ... I ve seen the beam hanging technique ... but Ive also seen sturdy Step ladders used as well
to hoist... simples ... etc..
Alb
Alb
- thumperslaw
Block of wood under the side stand and car jack on the sump
Works for me
Works for me
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
A simple paddock stand, or turn the bike upside down like a pushbike... easy...
What's your location your welcome to borrow mine if your local
thanks for that guys,im near norwich,I had a paddock stand come with the bike but it picks up through the wheel spindle which seems
strange,cos then the wheel wont come out,im trying to make some blocks to fit each side of the swing arm
thanks for you thoughts.
guitarman
guitarman
