Spraying rads
- thumperslaw
Spraying rads
What paint have you used to spray the rads with?
High temp am guessing??
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
- agentpineapple
Re: Spraying rads
i've used different types of spray, but the best by far is frosts/eastwood rad paint, very easy to use and a great finish,plus one can will do a lot, the downside is it ain't cheap....gloss and satin finish...
http://www.ebay.co.uk/itm/Eastwood-Radi ... 25739619ea
Re: Spraying rads
Yep, Eastwood radiator paint is what I have used as well
It's specifically designed for radiators
- thumperslaw
Re: Spraying rads
How many tin's did you use?
Also spray on to rad with no primer ?
K100 "flying brick"
K100 "flying brick"
Re: Spraying rads
1 tin, no primer and still got some left
- thumperslaw
Re: Spraying rads
Thanking you good sirFlatline wrote:1 tin, no primer and still got some left
K100 "flying brick"
K100 "flying brick"
- agentpineapple
Re: Spraying rads
with one rattle can i did, 4 rads, and 3 oil coolers, and i've still got a little bit left over, great product, i wouldn't use anything else.
Re: Spraying rads
+1 on that Marty
- freeridenick
Re: Spraying rads
Anyone got any advice on drying times between coats and number of coats? Got a can of the Eastwood rad paint but there's nothing to advise on the can or the Frost website. I've got two radiators, grills and the oil cooler to do.
Re: Spraying rads
Sure it was on the can when I did mine, I'll check & get back to you...things to do & wheels to change might be some time.freeridenick wrote:Anyone got any advice on drying times between coats and number of coats? Got a can of the Eastwood rad paint but there's nothing to advise on the can or the Frost website. I've got two radiators, grills and the oil cooler to do.
Re: Spraying rads
Nope nothing on the can re drying time just the advice to use two fine coats & allow to dry between.
If IIRC it was quite warm when I did mine so I didn't have a coat on.
So sprayed the rad's & just let them dry for a couple of hours & gave it a second coat.
- freeridenick
Re: Spraying rads
Thanks for that. Think I'll test on the oil cooler and see what it comes out like. Less visible is I stuff it up.MacV2 wrote:Nope nothing on the can re drying time just the advice to use two fine coats & allow to dry between.
Re: Spraying rads
Thanks for the link also, mine are going black (silverstorm) this winter
Re: Spraying rads
Looks good on a silver Storm...
It was Black before I swapped B/W
