speedo
chris vtr virgin
speedo
Post by chris vtr virgin »
Whilst out on a run today my speedo went a bit wonky
It started bouncing about and staying zero for a long period of time
I changed oil and filter yesterday if that may have caused it have I knocked a connection?
All seems to be ok now but do I need to look for any problems
Where is the speedo pick up
Chris
Some twins have all the fun !!!!
Re: speedo
It by the rear exhaust .
Re: speedo
They usually do that when giving up the ghost - pretty expensive new but they pop on fleabay for about £20. Look near the rear CCT where it bolts in, and plugs into loom nr battery.
chris vtr virgin wrote:Whilst out on a run today my speedo went a bit wonky
Chris
Re: speedo
I would check the the R/R is earthing properly. That can cause mysterious electrical glitches especially with instruments. I would also get a multimeter on and check it's functioning correctly.
Re: speedo
Did you happen to wash the bike recently??
Re: speedo
+1 on the RR check, speedo or instrument cluster probs is often a side effect of voltage irregularities.
Check battery connections as well....
Jazzscot
Re: speedo
Post by Jazzscot »
tony.mon wrote:+1 on the RR check, speedo or instrument cluster probs is often a side effect of voltage irregularities.
+2 on the above.
Mine did exactly the same as you describe just before my R&R gave up the ghost.
Everything good is bad
Everything bad is good
chris vtr virgin
Re: speedo
Stuck a new reg/rec on it last year and its a finned type
It was washed the day before the run might be a water problem
Will look at all the other options this weekend
Thanks again
Chris :thumbup:
darkember
Re: speedo
Post by darkember »
Best I have atm. The speed sensor is just visible behind the cct and is held on my 2 bolts. I would IPA spray all your connections & keep the jet-wash away any delicate areas :thumbup:
Smokinjoe73
Re: speedo
Post by Smokinjoe73 »
You should open and spray all your connections with wire dryer, then smear them with dielectric grease for long term reliability. And never use a pressure washer anywhere near them. It can only lead to great unhappiness.
Check the votage across your batt terminals while the bike is NOT, then IS running to see if your RR is dicey. (Should be 12.something sitting, 13-14.something running.)
Givi wingrack,CBR600 dash,CBR1000 forks, corbin, mario nava carbon fairing, 2bro carbon cans, vista cruise, GSXR mirrors.
