Exhaust valve GSXR K6 1000
seb421
Post by seb421 »
Got more problems with the gixxer now :-(
Sometimes when I start it up it will manage to stall it's self after say 30 secconds
The exhaust valve in the link pipe is making horrible squeaking noises when shutting off the throttle and when changing down the gears or when you blip it in natural etc
I'm guessing the thing is not opening and closing as it should be, also found out it should be protected by a cover which isn't present on my bike so it's been lost with a previous owner when a race can has been on or something....
If I disable the valve in the open position following some youtube guide I found will it make the bike louder?
Will it cause any issues such as running lean?
Re: Exhaust valve GSXR K6 1000
It will be a little louder and you will loose some bottom end torque.....like you would notice....lol
Other than that you will be fine..... the FI should be able to compensate to keep things from blowing up though a power-commander would make it run better. :thumbup:
slower110
Post by slower110 »
surely it won't be as loud as the storm at 3am in the morning :lol:
I fitted the stock exhaust on mine yesterday, didn't connect the cable for the exhaust flap so it's open all the time. Took it for a quick run after, all ok, went as it should.
You should have bought a blade :lol:
Saintsman27
Post by Saintsman27 »
Hi bud ... with a tote scoop, lotto win or lucky 31 win you could get
yourself orf to Preston Suzuki and get a new bike ... hey we could all do
with a few squid bud :D ... saw that they had good deals with cash back
on several new suzuki..s ... seeing as you like em ..good luck har :thumbup:
With a name like Suzi it is going to nagg you. :lol:
Sounds like a good excuse for a power commander and a tune up if you ask me :twisted:
They're supposed to be quite receptive to a bit of a tweek if I recall :D
