Benny's Bike Parts
Moderator: VTRDark
Miztaziggy
Benny's Bike Parts
Post by Miztaziggy »
This is going to be a really long thread as there are 60 pictures to put up.
Adyf and I picked up most of the firestorm stuff from Benny's garage and Ady has very kindly cleaned it up a bit and taken photos for me to put on here. Thanks mate you're a star :)
It would be great if Marty or someone with similar knowledge could look through this and give me a budget price for each of the bits. If you could post up with a simple list of parts against a price.
If you would like to bid on a part please PM me.
1. Benny's helmet - no damage on it, still useable or perhaps a souvenir?
2. A random micrometer we found amongst other parts. Works ok.
3. Double bubble screen for firestorm
4. Fireblade seat cowl from his new bike
5. Rear hugger, we think from the blade
6. K&N filter for the storm
7. Some sort of gas mixing stuff that was with a compressor he used to spray his bike. No idea what these do.
8. 4 into 1 pipes, not sure what they have come off or what they will fit
9. Part broken engine. Cams and most of top end missing. Can someone tell me what parts if any will be worth salvaging from this?
10. A random torque gauge we found amongst some parts
11. Martin's rear paddock stand
12. Martin's front paddock stand. It's a good one in Aluminium.
13. Random selection of engine parts removed from the broken engine including an alternator and cover, levers, spindles, fans, relays etc
14. Rear sprocket carrier and spacer
15. Subframe and plastic under tray thing
16. The spray gun he used to spray the storm white
17. Swing arm and linkage. Sprayed black.
18. Wiring loom and electronic units
19. Fast action throttle. This was packaged ready to send, not sure if it had been paid for. If you're on here and have paid for this please let me know.
20. Exhaust pipes and hangers
21. A random massive roll of tubing.
22. An HID conversion kit and lamps.
23. The frame linked to the V33 VTR plate. His wife is sorting the V5 so for now let's assume it will be sold with that plate.
24. Tyres. Quite a few race scrubs. Most look pretty good. I might bid on some of these myself for the track. First photo shows the make and model and second shows the tread.
25. Firestorm wheels in white. Front has a tyre on it already.
26. Radiators sprayed black
27. Firestorm front mud guard
28. Fuel tap thing
29. Clocks. No idea of the mileage on these, if he already tried to sell these someone may know?
30. Rear light unit
31. 2 sets of electronic ignition unit things
32. Pillion foot rests
33. Front brake calipers and hoses
34. No idea what this is
35. Clutch cover
36. Thermostat (thanks Lloydie)
37. Front sproket cover and clutch unit
38. Air box
39. Standard blade exhaust. Not sure what to do with this.
40. Yolks and spindle
41. Rear brake caliper
42. Almost complete engine. Has 2 manual CCTs on it. Do we sell this off in parts, and if so, what parts are best to sell off, or do we sell this whole?
Re: Benny's Bike Parts
Did you manage to locate the cams for tony ?
Just thinking they might be in that engine ! .
Miztaziggy
lloydie wrote:Did you manage to locate the cams for tony ?
No mate couldn't find them. We did take the heads off that one and it has standard cams. We're hoping that he posted them during the week.
Steve6088
Post by Steve6088 »
If that engine is the one I sold him, then it's missing engine number so might have to be sold in bits.
Pic no 34 is the heat shield that sits over the front head shielding the carbs.
If benny's wife can't find v5 for the frame/plate it can be applied for using frame no etc.
Hairy biker
Post by Hairy biker »
Those gauges in pic 7 look like the manual type gauges for doing air con.
Of all the things I've lost I miss my mind the most
No sign yet, still hoping, He did pm me that he would get them out last weekend, so maybe they'll turn up during the week.
There will be lightened alt rotors on those engines, by the way- they'll be worth more than std ones. And there will be the fancy breathers on one of those engines, have a look.
if you pm the parts list, i'll put a reserve price on the items, just let me know buddy.
infairness I won't be that good at prices on items that aren't firestorm related.
The air box has vacuum release valves in .
Benny's Bike Parts
Pic 36 is the thermostat not a water pump .
thumperslaw
Post by thumperslaw »
You have a pm
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
No 8 has zx9r wrote on it? Or am I pointing out the obvious! :?
Gazfirestormowner
Post by Gazfirestormowner »
Would be interested in front and rear paddock stands
Miztaziggy
Wattys1 wrote:No 8 has zx9r wrote on it? Or am I pointing out the obvious! :?
Yes mate, but without trying them on that bike I can't be sure that's what they're for. Also AFAIK Benny never had a ZX9, no not sure why he would have these. All I can think is they are mislabelled or they will fit something else.
