New VTR 1000 today
New VTR 1000 today
hi guys, i bought a firestorm today and was told it had stage 1 dyno, how do i know if no receipts and also what does stage 1 mean and do?
V-Twin Virgin and loving it!!
97 VTR 1000 Firestorm
97 Bandit 600 Fighter. 92 FZR 1000 RU EXUP
94 RF 600R. 2010 Kindoad Cyclone 125
Re: New VTR 1000 today
Check you first post for general advice
It means that the needles and main jets in the carb's have been swapped out, along with the slide springs... Perhaps also slides have been drilled with an extra hole... The result is mixed, some say good, I say doubtful, since you get crap fuel mileage and not that much gains in either power or usability...
Best way to confirm is to have a look in the carb's...
Stage 1 is sales talk for making it sound special. It's adjustable needles with a different taper from standard and Main jets that are tapered and are measured by flow rate. They are more than likely size 180.
To determine what your carbs have you have to strip the carbs down as Tweety says. If it's UK dynojet kit there wont be any springs.
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=25177
Ok, so what's stage 2?
- agentpineapple
thats normally when the solid fuel booster rockets seperate from space shuttle...........BigJ1111 wrote:Ok, so what's stage 2?
http://www.revolutionuk.co.uk/revyourbike.htm
agentpineapple wrote:thats normally when the solid fuel booster rockets seperate from space shuttle...........BigJ1111 wrote:Ok, so what's stage 2?
OK as a rough guide but there is no definitive answer. Stage 1 is a mildly tuned engine with jet kit, higher flowing air filter and slip on race cans.
Stage 2 would be even more tuned with a full race exhaust system, aftermarket cams and maybe higher compression pistons, ported heads.
Stage 3 would defiantly be higher compression pistons by now and a more aggressive aftermarket cam profile than stage 2, oversize valves, open airbox or ramair. By this stage it would not be very suitable for the road and very touchy at low down speeds.
Basically each stage is getting closer to a full on race bike and not suitable for the road use. There are lots of other things that can be done like lightened crankshaft, con rods etc etc. Every manufacturer and every person will have different ideas as to what gets done at what stage in the progression. I've seen sites where they add a stage 4 and 5. 4 being the addition of Nitrous or Turbo's, and 5 using race fuel. WTF
When it come to manufactures like Dynojet offering jet kits for different stages it's used more as a sales marketing pitch. There maybe subtle changes like different needle profiles that are designed for the use of no airbox and/or the addition of drilling holes in the carb somewhere. But tuning (jetting) carbs is not always going to be a case of following their instructions to the letter. For example with a standard engine and Dynojet kit the addition of the extra lift hole in the slide is not necessary and may make thing worse. The same for Dynojet springs. And on a side note Dynojet do not supply springs with a UK kit but do with the US kit, They also supply a bigger selection of main jets with the US kit. These kits are both marketed as Stage 1 jet kits. If you ask me it's a con. And with a standard engine and no aftermaket air filter you can achieve the same if not better by shimming the standard needles just to richen up the midrange a bit. This is where it lacks as standard because of emissions control out of the factory and the addition of an open exhaust which leans things off a little more.
I thought stg1 had hi comp pistons /hi lift cams/ port and polished heads / breather work done / full stage 1 exhaust like yours Carl .
Stage 2 more work and parts
Stage 3 warp drive
Stage 3 warp drive
I was always told that if you put on a free-flow after market exhaust PLUS the free-flow air filter, then at least do a stage 1 carb kit.
The first VTR I had had the after market cans & air filter ... got great mileage ... it was running lean as hell (not so good for motor life); there was hardly a trace of deposits out the end of the can. Mileage: 16 km/litre (standard bike = 14.5 m/litre), so, a 14% increase in mileage. Now I run a stage 1 with after market cans and air-filter ... I get 13.5 km/litre. Oddly enough, I had a set of Micron cans on, and changed them to a set of cheap DanMoto GP cans and fuel economy improved (14km/l) yet the soot in the end of the can suggested it was richer than with the Microns.
- bigtwinthing
Learn to ride it first, then upgrade the Forks to "Rogered" results are great.
Your right. Glad you enjoying them Paul. I'm thinking of getting a brace on mine as I'm sure, but not 100% positive, I experienced a bit of flex in them for first time yesterday on a big sweeping high speed bend.Learn to ride it first, then upgrade the Forks to "Rogered" results are great.
It never ceases to amaze me how many people are sucked in by the sales/marketing crap with stage 1 jet kits as if the 1 is suddenly going to turn their bike into the first stage race bike. Aftermarket jet kits have got to be the biggest con/waste of money in the motorcycle aftermarket parts industry. Unless you have a modified engine or changed the airfilter then there is not much point as you may as well just shim the needles.
- bigtwinthing
I've only ever done engine mods once iam confident iam using all the power OR it makes it run smoother. I had an Ivans jet kit on all my Fazers, not for more speed but for smoother fuelling. Most 1000cc bikes are well powerful enough, making them handle better is by far a better thing to do, Bikes to me is about cornering and leaning( just like skiing) my mate has a TRX 850 with modded forks and an Ohlins shock. On twisty roads you need to be a great rider to keep up with him, i can't. My Storms plenty fast enough for me, and once the WP shock is on along with the forks i think i will have the perfect bike.cybercarl wrote:Your right. Glad you enjoying them Paul. I'm thinking of getting a brace on mine as I'm sure, but not 100% positive, I experienced a bit of flex in them for first time yesterday on a big sweeping high speed bend.Learn to ride it first, then upgrade the Forks to "Rogered" results are great.
Is your jetting standard then Carl ??cybercarl wrote:Your right. Glad you enjoying them Paul. I'm thinking of getting a brace on mine as I'm sure, but not 100% positive, I experienced a bit of flex in them for first time yesterday on a big sweeping high speed bend.Learn to ride it first, then upgrade the Forks to "Rogered" results are great.
As good as with the exception of the factory pro needles and a slide hole blocked in each carb as I run two tall V stacks. I shall be putting the BMC street filter back in for this Summer so will be having a play with things.Is your jetting standard then Carl ??
