boost joint
boost joint
Has anyone one broken a new boost joint off in your block?? Because this dude just did!! any idea how to get it out??? Please someone!
Re: boost joint
First you'll need to gain access to it by removing carbs - then get a fine easyout to extract it
Re: boost joint
I thought a boost joint was a strong spliff
Re: boost joint
I thought you had a boost after a joint when you get the munches
Re: boost joint
I thought the boost joint was over the pond talk for a vacuum take off.
now I'm confused.
A joint will always be a joint to me.
