I might not be able to repair this one.
I came over all enthusiastic this evening, and started to pull my engine apart.
I found these in the exhaust system:
The other bit of the valve head was sitting in the inlet tract under the carb.....
I may need a few parts. :think:
Miztaziggy
Re: I might not be able to repair this one.
Post by Miztaziggy »
Well, although I can tell that doesn't look good, I don't know what that actually is....
Is that a valve?
Mushrooms :eek2
That well and truly exploded. So how far down the exhaust did they end up.
In the collector, under the engine.
They may have been travelling at a fair velocity......
Hairy biker
Post by Hairy biker »
Maybe your bike has decided to make itself one of those Yamaha ex-up valves :lol:
Of all the things I've lost I miss my mind the most
warby221
Post by warby221 »
Would have thought it was just a five min job for a man of your caliber tony
Hammer it flat weld it back together polish it up grind the seats back in and bobs your mothers brother :D :D :thumbup: :thumbup:
Lol
In the words of dirty harry “an mans got to know his limitations” :Gun1: :Gun1: :Gun1: :Gun1:
I’m assuming the head and pistons are a bit worse for were to
gotta say when you do a job u do it right m8
darkember
Post by darkember »
Jeepers Tony, what kind of abuse were you giving that poor engine :? :?
Saintsman27
Post by Saintsman27 »
You been doing them Mexican explosions then .. :lol: :lol:
har :thumbup:
Alb
sh1t ... hows the hi comp pistons ?
Yeah that'll be alright nothing a dab of superglue wont cure...
ging500
Post by ging500 »
I won't tony to post pictures of the rest of the engine once taken to pieces. The head is not going to look pretty.
Darknomad
Post by Darknomad »
when ever has anyone says i want to see the head ended up pretty.
east london/essex [leyton ]
Z28DUNC
Post by Z28DUNC »
Looks like its been chewed up and spat out! 8O
What where you running it on AVGAS? :lol:
you will want to keep those bits, polished and mounted...........a memorial to your mechanical sympaty :lol:
Might take a bit of polishing:
Well, as I always say, if you're gonna do it at all, do it properly.
Mind you, the front one is still ok....
