Page 1 of 2
Good day and welcome...
Posted: Fri Sep 27, 2013 1:14 pm
by Baldy
Just got my first V twin, 1999, red, 24000 mile,s very tidy and running like a pig!!
Had new front head after the dreaded CCT failure, been fixed apparently but its now misfiring on the rear cylinder, could be something simple as i'm sure it has had no set up time since the repairs. Got manual CCTs going in next week and a basic set up might get it running a little better i hope.
By the way i'm Martin up here in West Yorkshire, 10 minutes from Squires Cafe.
Re: Good day and welcome...
Posted: Fri Sep 27, 2013 1:32 pm
by AMCQ46
welcome to the club mate, sorry to hear you have got problems already [assume this wasn't Tasum's Bike
get a thread started in the workshop section with your symptoms and we will see what help we can give
Posted: Fri Sep 27, 2013 1:37 pm
by Baldy
No it wasn't...got the bike on the cheap already knowing of the misfire issues.
Lots of similar type symptoms already in workshop areas, will start work on it when time allows hopefully next week.
Posted: Fri Sep 27, 2013 1:41 pm
by Jamoi
Welcome
Good luck with the bike, there's some really helpful gurus on here, incase you need some guidance or just fancy a bit of banter
Posted: Fri Sep 27, 2013 1:43 pm
by Virt
Jamoi wrote:Welcome
Just don't ask him or me
Welcome to the forum, hope it's something easy and simple to solve
Posted: Fri Sep 27, 2013 1:58 pm
by agentpineapple
hello and welcome baldy/martin....
Posted: Fri Sep 27, 2013 3:23 pm
by lloydie
Hello and welcome
Time to get the spanners out
Posted: Fri Sep 27, 2013 4:29 pm
by Jamoi
Virt wrote:Jamoi wrote:Welcome
Yup, we are intellectually equivalent to pond life!
(Well I know I am!)
Posted: Fri Sep 27, 2013 5:18 pm
by VTRDark
I'm sure you have posted one helpful post. IIRC it was something about the vacuum pipe on the petcock. The idea is that you learn things and then the rest of us don't have to do all the work
Welcome Baldy. Is it misfiring or popping, banging and running like a pig. You may want to check the vacuum on the petcock.
If it's not this then maybe the timing has been messed up when doing the CCTs As AMQ said start a new thread and we will work out what is wrong.
Posted: Fri Sep 27, 2013 6:18 pm
by Jamoi
Virt also successfully diagnosed someone's bike (not revving past 7K) as timing out by 180deg a while back...
I'm still working on being helpful, but in the mean time I'll just be... umm... here!
Posted: Fri Sep 27, 2013 6:44 pm
by macdee
wello and helcome
Posted: Fri Sep 27, 2013 7:24 pm
by darkember
Hello & welcome
Posted: Fri Sep 27, 2013 8:42 pm
by lumpyv
welcome in
Posted: Fri Sep 27, 2013 9:01 pm
by Hairy biker
Hello
Posted: Fri Sep 27, 2013 9:05 pm
by oorwullie43
Welcome to the madhouse!!
