Heel plates for Harris Rearsets....
- cliveyandrews
- Contact:
At present I have some carbon ones, but they don't fit in well with the hi level links, and I don't like the carbon look. Anyone using an alternative? I've been looking at ZX6R or Fireblade units. IIRC the centres are 48.5-50mm ish (Yamaha Thunderace Brembo M Cyl) and I will almost certainly have to open holes out a bit to fit the M Cyl mounting bolts anyway) I've been mailing all the breakers - most of them can't be bothered to respond....
I'd appreciate thoughts/advice/suggestions....
Audi, Vide, Tace
Audi, Vide, Tace
Re: Heel plates for Harris Rearsets....
CBR600rr heal plate fit.
- cliveyandrews
- Contact:
Cool, ta! I'll get onto fleabay....!cybercarl wrote:CBR600rr heal plate fit.![]()
Audi, Vide, Tace
Audi, Vide, Tace
What you doing with the old plates
- cliveyandrews
- Contact:
Hadn't really thought - spares box probably. They're not very nice - cracked where they bolt through....macdee wrote:What you doing with the old plates
Audi, Vide, Tace
Audi, Vide, Tace
Standby...........Checking boxes in garage......
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
I've got one only, its the gearchange side if you want it.
IIRC ZX10r plates fit too.
CJ
CJ
Or- cheap as you like with 2 hours to go.
http://www.ebay.co.uk/itm/Honda-Cbr-Hee ... 3f29b84fd2
- cliveyandrews
- Contact:
Arses - missed it! They look perfect!Jonesey wrote:Or- cheap as you like with 2 hours to go.
Audi, Vide, Tace
Audi, Vide, Tace
- cliveyandrews
- Contact:
Ended up with ZX6R ones - just the right shape. Just getting the left hand mountings drilled and tapped for M8 and that's the last bit remaining - barring a polish!
Audi, Vide, Tace
Audi, Vide, Tace
