Shear bolt anger!
Shear bolt anger!
Currently sat in my garage surrounded by broken tools, a very knackered right arm and a feeling of self pitty!
I'm trying to get the shear bolts out which hold the ignition barrel in. I've drilled down into them about 15mm deep, and beveled the top brass bit of the bolt, and I still can't get the damn thing apart!!!
Any suggestions before I start crying? :lol:
Re: Shear bolt anger!
12mm drill bit . Drill down 5mm then the top just falls off :-) or if you no longer need the top yoke get a angle grinder out with a cutting disc and cut in 3mm above the lock base job done
Thanks Lloydie, I'll pick up a new 12mm bit tomorrow as all mine are now blunt despite using cutting fluid :(
I've moved on to re-routing cables etc now, as I don't want to look at that damn top yoke again tonight!
Angle grinder sounds good to me :biggrin You could try slotting the top and undoing them. If your going to use a drill you need Cobalt drill bits.
Thanks Carl, will pick a new cobalt 12mm.
I might whip out the angle grinder, just for the fun of it, it's a bit late now... bloomin' neighbours :(
Pleased with the top yoke though :)
Jeez how much have you dropped them forks. :lol:
ging500
Post by ging500 »
Jamoi wrote:Thanks Carl, will pick a new cobalt 12mm.
There was me thinking you were a man. Can believe you have put a high rise conversion on !!
cybercarl wrote:Jeez how much have you dropped them forks. :lol:
To the floor! :lol:
They're actually standard height, but without the stock clip-ons on top of the yoke there's a lot of fork tube sticking out!
Ging500, I'm a "manboy" despite my ultra tough exterior... :lol: :lol:
I thought you'd have guessed when we met, I'm a massive pansy! Can't wait to try the new bars out, should be good for reducing front tyre wear :)
Yes off-course it is, I'm having a divvy moment. :oops:
ging500
Post by ging500 »
To the floor! :lol:
o dear !!
o dear !!
Not another one, he has Virt :lol:
Jamie just to add insult to your dent manboy pride...
Got mine out even with my wonky wrist... :wink:
MacV2 wrote:Jamie just to add insult to your dent manboy pride...
Ok now your just showing off!
http://youtu.be/hHHB00Nu3Ak
Serlant
Post by Serlant »
To get the shear bolts out of My original yokes when I changed to 929 forks I just used a chisel and hammer and we'll... Smashed them around.
seb421
Post by seb421 »
i remember doing them when i did the 954 front end conversion, bit of a bitch they was didn't take to long tho iirc
