Top yoke conversion problem
For some reason I seem to be struggling with everything! (Can I use the 'Essex' card for all my downfalls Mac? :) )
I can't get my throttle cables to route anywhere without causing them to kink or get squashed :(
Any tips? Image
Re: Top yoke conversion problem
Eh try undoing the nut where they go into the throttle housing, turn the metal bit to a new position & tighten it back up. Try various angles of dangle until happy.
''Can I use the 'Essex' card for all my downfalls Mac?'' No you cant Jamie, not all people from Essex are Dim, just a few of YOU... :lol:
:lol: :lol: :lol:
Thanks Mac! Bazza is from Essex & he is bright as a button, I'll go sit in the corner & dream about orange women, white Ford Capri's and Burberry :lol:
Jamoi wrote::lol: :lol: :lol:
So am I...from Essex that is not dreaming about Oompa Loompa's...
Jamie, you will need to move your Brake lines, but the throttle cables will stay where you have them. I will send photos of where mine are
mattycoops43
Post by mattycoops43 »
Fazer runs them above the bar, is that worth a try, it's quite a neat solution. So they go up and forwards, then turn down between the stanchions.
AMCQ46 wrote:Jamie, you will need to move your Brake lines, but the throttle cables will stay where you have them. I will send photos of where mine are
I can't get enough length to go round the front of the fork tube (like standard iirc), it's not like I've got ape hangers either :(
You will need to loosen the throttle cables to their max both ends. Bars and carbs. :thumbup:
My throttle cable runs above the brake lever and round the outside of the fork .
ging500
Post by ging500 »
I don't think anyone wants to know what you dream about mac !!
Mine run like this
Read that again Rob... :lol:
darkember
Post by darkember »
See mine below:
Thanks for the photos guys :)
They really help, I ended up with the same layout as you Ali, seems to work ok and it's good to see someone else with the same setup.
The only problems I encountered were:
1- removing the shear bolts - angle grinder
2- routing the throttle cables - got there in the end.
3- Galfer brake hoses are too short! Managed to get a local hose shop to make some better quality ones up for half the price, also had the choice of blue, red, white & black! Went black because I'm boring.
So, very minor problems overall :)
I took it for a little spin round the block, my first impressions are...
- I have to be a little more sensitive with steering inputs, those wide bars have lots of authority!
- field of vision is really good as I'm more upright so I'm not bending my neck round my shoulders to look around.
- wheelies are much more stable
- Kneedowns: no problem! Difficult to gauge exactly how much more tyre I have left but, I'll get that lean angle memory built up over time
- new braided hoses have transformed the feel of the front brakes, much more positive.
- could do with moving the levers towards the center of the bars a bit more as I'm pulling with my two fingers very close to the pivot, meaning it takes more effort as there's less leverage.
- skinny, medium renthal grips make me feel like I'm on my crosser! :D
Overall, very pleased with the change, but it does feel odd at the moment. Soon get used to it though.
You chaps are really tempting me again :problem: :D
Glad to hear you got the there in the end Jamoi :clap:
Any idea what length brake hoses you end up getting :?: (just in case :wink: )
