Effin condensation
lanny
Effin condensation
Post by lanny »
Uncovered the bike this morning and its dripping with condensation :wtf:
Anyone had the same and got a solution :confused
Re: Effin condensation
What did you park it on ?
lanny
Post by lanny »
Its in a nice timber shed parked on the bike table with a bike cover over it. There was a slight ground frost this morning before warming up nicely around 11am. Thinks im going to have to put some heating in there, I was thinking something like a tube type greenhouse heater placed under the sump, they dont use much electric and should be enough to keep the damp off. Hopefully!
macdee
Post by macdee »
lanny wrote:Its in a nice timber shed parked on the bike table with a bike cover over it. There was a slight ground frost this morning before warming up nicely around 11am. Thinks im going to have to put some heating in there, I was thinking something like a tube type greenhouse heater placed under the sump, they dont use much electric and should be enough to keep the damp off. Hopefully!
you need to ventilate the shed to let the air through
also insulate the walls and ceiling and get some sunlight in there this will help
+1
A nice little solar powered fan would do the trick, have a look at Maplins or camping supplies places.
If your cover is impermeable and retaining moisture then get a new cover along with the other suggested measures to get some air flowing.
http://www.specialisedcovers.com/bike-c ... -lite.html
Ideal for frequent outdoor storage, this lightweight cover is 100% waterproof and breathable. The excellent breathability of the Stormshield fabric means the cover can be put on a wet bike and the remaining moisture will permeate through the cover. The 100% waterproof protection ensures that your bike is never exposed to the elements, even in harsh weather conditions.
Many manufacturers can make a waterproof cover for your bike, but breathability is crucial. Moisture rising from the ground will get trapped under the cover. If the moisture is unable to escape it can damage paintwork, rot seals and accommodate mould. The technology behind our Stormshield Lite fabric allows moisture to escape from the surface of your bike, keeping it dry. All Specialised Covers’ fabrics are non-abrasive.
darkember
Post by darkember »
I suggest do not heat the shed as that will make it condensate more. You need to install a dehumidifier on a timer. Then i would cover the bike with a blanket.
lumpyv
Post by lumpyv »
if its In ashed I wouldn't bother covering it.
Just use an old sheet to keep the dust off.
+1 on getting some ventilation, bit of fresh air blowing through.
Your not putting the cover over the bike while it's still warm are you ?
Agree. It's the differences in outside and inside temps that cause the condensation in the first place.
Dehumidifier and ventilation along with a proper bike cover that can breath is the way to go.
BigVeeGrin
Post by BigVeeGrin »
Wicky wrote:If your cover is impermeable and retaining moisture then get a new cover along with the other suggested measures to get some air flowing.
:thumbup: I have one of these and they are made to fit the Storm - excellent quality, however, I did have to wait five weeks as they are made to order it seems
if its indoors then just cover with an old blanket
