Quick question
playerone
Quick question
Post by playerone »
Can you remove the chain without splitting it or removing front sprocket?
Cheers.
Re: Quick question
playerone wrote:Can you remove the chain without splitting it or removing front sprocket?
Cheers.
Yes.
You will have to take off the footrest to do it but it can be done.
playerone
Re: Quick question
Post by playerone »
Cheer's Mac, didn't want any nasty surprises when I get round to fitting the braced swingarm :thumbup:
Re: Quick question
The chain will need breaking to fit the braced arm though mate.
playerone
Re: Quick question
Post by playerone »
Kev L wrote:The chain will need breaking to fit the braced arm though mate.
It's already through braced swingarm :thumbup:
Re: Quick question
Ah that explains it...
You will need to get the rear on a stand loosen off all the bolts. Then figure out how to get the s/arm off by way of suspending or the Abbastand engine mount hold.
I always go for the suspend from the rafters trick but then I have the rafters to do it. Stepladder A-frame or homemade gallows are the other options.
Once suspended fully dissemble then rebuild.
Top Tip. Swingarm bolt normally passes through from the left with nut going on the right hand side. This of course means that for future front sprocket removal it all has to come off again.
When rebuilding this time pass the spindle through from the right hand side, then next time you need the sprocket off you only have to take the nut off to remove the footrest... :thumbup:
Re: Quick question
MacV2 wrote: When rebuilding this time pass the spindle through from the right hand side, then next time you need the sprocket off you only have to take the nut off to remove the footrest... :thumbup:
Ahh I was thinking about that when I dimantled thr rear on my bike too! Glad its ok to do as you have suggested. :thumbup:
Sent from my GT-19505 using Telekinesis
playerone
Re: Quick question
Post by playerone »
Will have to be abba stand method, used it successfully doing the single sider swap so should be ok this time too, cheers for the tip about putting bolt through other way :thumbup:
Re: Quick question
That is funny as mine came with the bolt in that orientation.
All I have ever had to do was remove the bolt to pull the footrest from the sprocket cover side for chain removal.
Not sure why yours would be put in the other way...... though I am one of the few who bought the bike new....
