any one know of any one who does a full kit i.e front fork bobbins, rear swingarm and engine protectors
ive seen the r&g engine protectors for £100 but wondered if any where did a full kit
crash protectors
Re: crash protectors
Never seen a full kit but R&G are good
CBR125 - XJ600S DIVERSION - YZF600R THUNDERCAT - VTR1000 FIRESTORM
I still crave a supermoto...
I have never seen a full kit either. I am not a fan of the R&G ones as it means making a hole in the fairing. I prefer the sty;e that either mount to a bracket over the rad or mount to the vertical upright bar on the frame juts above the rad.
http://pdq1.com/part.php?PartID=2413&Ma ... =144&Year=
You could always buy some cheap bungs and make or get made some brackets.
http://www.ebay.co.uk/itm/320920772465? ... 1423.l2649
Like these ?
How would these fit, obviously you would need to drill the frame bit would it need to be threaded.
You wouldn't want to be drilling through the frame. Ideally you want to mount them to a bracket that attaches to the frame. But don't forget they need to protrude past the rad and fairing so longer bolts and a metal sleeve/spacer would most likely be required.
