fuel tank
reggy5
fuel tank
Post by reggy5 »
hi all just a quick question is the 19ltr tank a straight swap for the earlyer 16 ltr tank?
vtr 1000 firestorm
Re: fuel tank
reggy5 wrote:hi all just a quick question is the 19ltr tank a straight swap for the earlyer 16 ltr tank?
No but it's easy to do as you need to swap a few things over not just the tank
reggy5
Re: fuel tank
Post by reggy5 »
is the tank wider , higher? also what needs changing over. need more mpg lol.
vtr 1000 firestorm
Virt
Re: fuel tank
Post by Virt »
reggy5 wrote:need more mpg lol.
You won't get any better fuel economy from the larger tank, i have a 19ltr and I average about 31 :lol:
reggy5
Re: fuel tank
Post by reggy5 »
tank range i ment doh lol
vtr 1000 firestorm
Re: fuel tank
Re: fuel tank
:lol: :lol:
You have got to find a 19L tank first. :roll:
Tweety
Re: fuel tank
Post by Tweety »
You need to swap over the petcock, and mount for it, as the 19L has the petcock mounted to the frame, not the bottom of the tank...
And you may want to fiddle with the fuel level sender, or RLOD sensor, but that's fairly optional...
Other than that, it's a straight swap... It's shaped slightly different around the bars, so you might manage to pinch your fingers at full lock with the stock clip-on's if you work on it a little, but that's about it...
