So if anyone can tell me the outer diameter needed for thge spacers so I can get some tube ordered up I would be rather greatful
my forks are apart at the minCkennedy wrote:Does anyone know the outside diameter required for the spacers used when fitting new fork springs. When I fitted mine I had to use what ever I could lay my hands on to use as well as the original spacers due to the new springs being shorter than the old ones![]()
Just read this the spacer is 99.5mm long notCkennedy wrote:Cheers tony. Without the spacers its impossible to set up the pre load. What length spacers do you have? Going to need something 110mm. If the standards are 95mm like Macdee says then I need another 15mm ontop of that. Maybe another 20mm. Failing that I'll try and find a length of tube and cut it down.
Which springs are you using then and how long are they as the originals are quite short.new springs being shorter than the old ones
