Repairing a cracked fairing
brownie
Post by brownie »
Can anyone recomend a product for repairing a cracked fairing?
Thanks in advance.
Depends on how good you want it to look 8O
Cheep way Aroldite :D
More expensive way Plasic weld and a respray
Very Expensive way. Replace it with new :lol: :lol:
What are you looking for?
(sory,bit flippent. Pissed again :lol: )
brownie
Post by brownie »
Pete.L wrote:What are you looking for?
:lol:
Sorry, should have made myself clearer.
Apparently, according to the chap I bought it off, the bike fell over onto its right hand side. This has left a crack in the right hand side panel, approx 2" long, a piece of the panel has been pushed in a bit. Just want to push it back out and bond it from behind, not bothered about finish as no one will see it.
Araldite sounds the trick then.
Ahh! cheep and easy.
:lol: Just like me :lol:
Druid
Post by Druid »
You can use glassfibre mat and resin for this sort of repair - buy a kit from Halfords.
Plastic welding will produce a tidier finish, there's quite a good guide here
W@zzA
Plastic repair kits
Post by W@zzA »
Get a small plasic repair kit from your local dealer or one of the mail order companies! It's basically dental acrylic and the kits work very well :!:
Warren
If it aint got the throb it don't do the job! PB.
smeggy_smeg
Plastic Repairs...
Post by smeggy_smeg »
I repaired the fairing of my old ZX6-R by lining up the crack(s) and using a soldering iron on the inside to seal.
Worked a treat and was barely visible.
T
thehazmatguy
Re: Plastic Repairs...
Post by thehazmatguy »
smeggy_smeg wrote:I repaired the fairing of my old ZX6-R by lining up the crack(s) and using a soldering iron on the inside to seal.
T
Yeah.. I have done that too. It takes a little time and stinks up the apartment but it works great! I used a scrap piece of plastic from another fairing and worked it into the crack area. That process works awesome.
Also, for small hairline cracks you can use this:
http://www.hobbylinc.com/htm/amb/amb110.htm
It is like water and flows into the crack from the brush. This isn't like a glue or a patch. The chemicals in it MELT the plastic parts back together. Great stuff.
You know the Austin Powers movies? I have always wanted to date someone like Allota Fagina... but I always seem to date her sister Sandy.
