Fork lowers colour match
Does anyone know the closest colour match and best paint for fork lowers (silver) Sending them to roger in the next week or so and want to freshen them up before refitting.
Re: Fork lowers colour match
No, definitely silver.
Brown won't work at all, no, Sir, not at all.
If painting the lowers with each fork leg as a complete unit don't forget the little bit that lips around the top of the leg by the oil seal/dust seal. Pry the dust seal up and off out the way, but don't get paint on the inside the leg. You should etch prime them first for best adhesion and longevity of the paint. As for colour...sorry I'm with Tony, Silver!!!! Decide on which paint you want to use first. It needs to be pretty tough to withstand stone chips.
Wire wool, degrease, hammerite smooth silver. Nothing else reqired. Etch primer is not needed if you paint over whats there already.
That'll be spray hammerite Lee? And it's a close match to original silver?leevtr wrote:Wire wool, degrease, hammerite smooth silver. Nothing else reqired. Etch primer is not needed if you paint over whats there already.
+1 Hamerite Smooth. You can get a good finish if it's warm enough and a quality brush.
Theres A Hare in The Turnips.
Yes spray. For christ sake dont use the brush on stuff !!! Just make sure its the smooth not hammered finish. They look factory new when done.Watty wrote:That'll be spray hammerite Lee? And it's a close match to original silver?leevtr wrote:Wire wool, degrease, hammerite smooth silver. Nothing else reqired. Etch primer is not needed if you paint over whats there already.
Not only hammerite'd mine but also adding fork gaiters to help keep stations cleaner.
Paintwork needs a light rub and recoat but needs another three weeks to cure off before paint can be added.
Well yes adding gaiters to the station will clear it out in no time.but also adding fork gaiters to help keep stations cleaner
Good idea using gaiters What size did you use. Have you got a link for them.
would clear it out in no timecybercarl wrote:Well yes adding gaiters to the station will clear it out in no time.but also adding fork gaiters to help keep stations cleaner
That's the only trouble with hammerite! Once you've missed the recoat time your buggered for weeks Gaiters are practical but not sure i like them!Moocher wrote:Not only hammerite'd mine but also adding fork gaiters to help keep stations cleaner.
Yes Hammerite is not problem free.
Gaiters or as they call them Gaitors were from Ebay - bertrum 4572 - TRIUMPH BSA NORTON BRITHISH BIKE FORK GAITORS £14 + postage.
My PC is sulking so I can't see how to copy link from Ebay and it won't show Flash Player in IE but will in Firefox
Grrrrrrrr.
I thought I wrote stansions but may have written s-t-a-n-t-I-o-n-s which spell checker corrected to stations. OK I give in they are Fork Legs
Clean the fork leg, add a coating of ACF50, fix the gaiter with nice thick zip ties, job done. A bit 'utility' for a 'classic bike' these days but less bother than getting the legs re-chromed and IMHO looks better than slightly rusty forks.
Grrrrrrrr.
