rusty little bits
countrymick
rusty little bits
Post by countrymick »
striped out my rear suspension lincages today.the 3 in the alloy link are perfect actualy look like new.
the 2 in the steel link wernt even seazed they just fell out as metallic gravel :thumbdown:
the center shaft is totally knackered to,ive never seen bearings quite so bad.there is a very slight ovality to the two bolt holes to.
half a mill or so.looks like ebay later.realy glad I checked them now.i better have a look at the swinging arm while its in bits.
carmanbikes
Re: rusty little bits
Post by carmanbikes »
How many mile it done, Gonna strip mine later and I am dreading what I am going to find, Mine is a 2001 on a Y reg done 31,000 miles
countrymick
its done 25000.the rest of the bike is absoloutly immaculate,those linkages looked a bit unloved though.out of site out of mind.
going to try david silver or some were for center shaft
Fit grease nipples and give them a lubeing every now and then .
I had linkages of a 5k bike that were scrap .
It's more to do with wether it's been a winter bike and jet washed over mileage .
I also have a set from a 40k bike and they are as new !
countrymick
yep lack of maintenance.its the bearings onto the swing arm that are shot.were is the bet place to get the linkages from???
countrymick wrote:yep lack of maintenance.its the bearings onto the swing arm that are shot.were is the bet place to get the linkages from???
Try ebay for whole second-hand linkage replacements if they are that shagged / see the thread in the workshop knowledgebase for where to get new bearing /seals components from.
countrymick
I think the main linkage is usable its just the center sleve and 2 bearings that are totaled
Stratman
Post by Stratman »
I bought my bits from the local Honda dealer, C J Ball. They weren't that expensive really.
Isn't opinion divided re the grease nipple thing?
countrymick
the roller bearings have seals in there outer edges so in theory grease wont be able to enter even with a nipple fitted.
a yearly strip and check job I think.it also gives you a chance to visualy check the bearings.
countrymick
getting my bearings and linkage tomozz so this weekend will be spent getting the back end greased up for the summer.
time to have a look at the forks next :thumbup:
Stratman
Post by Stratman »
countrymick wrote:this weekend will be spent getting the back end greased up for the summer. :thumbup:
Ooerr 8O
countrymick
you have to start some were.i was going to get the forks off next,maybe off to roger or might try them mysely.
I will take a good look once there off and decide from there.carls how to looks prity comprihencive. :thumbup:
Moocher
Post by Moocher »
countrymick wrote:the roller bearings have seals in there outer edges so in theory grease wont be able to enter even with a nipple fitted.
I fitted a grease nipples ......
The bearings I got recently have one end open. I fitted them with the closed end on the outside and open end in the middle to take in grease as pumped in via the nipple.
I got all three link bearing pins from David Silver ( about £30)
countrymick
got my linkages sorted. :thumbup: front forks need a good seing to next then the storm should be ready for spring. :?:
