carb coughing???
firestorm1980
carb coughing???
Post by firestorm1980 »
Ok brainiacs!!
Every now and then when either sat stationary or slowing down i can hear what sounds like the carbs coughing and the revs drop!!
Any ideas??
Re: carb coughing???
Normal ,don't worry you'll get used to it
Virt
Post by Virt »
Mine does it too, there's two options.
1) Ignore it.
2) Keep the revs high so it doesn't happen :wink:
firestorm1980
Its driving me insane!!!!
Must be a way of stopping it?? :Argue 1:
firestorm1980 wrote:Its driving me insane!!!!
Yep run it a little rich and fit a +4 ignition advance and a fuel pump
E.Marquez
Post by E.Marquez »
Proper jetting, synced carbs, no exhaust air leaks, PAIR gone.. ...and the carb fart is gone as well.
There is no need to live with it.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
gl_s_r
Post by gl_s_r »
E.Marquez wrote:Proper jetting, synced carbs, no exhaust air leaks, PAIR gone.. ...and the carb fart is gone as well.
That told you Lloydie... :lol:
I'm starting to think you know nothing about these bikes!
Hairy biker
Post by Hairy biker »
Mine used to do it all the time and would cut out as well, set the tps sensor and sync the carbs made a world of difference, it still does it occasionally bit no longer cuts out,it's probably running a sniff lean bit if I remember correctly you need a weird looking gizmo to adjust the mixture with the carbs on the bike
Of all the things I've lost I miss my mind the most
Explain yourself young man. :lol: :Ball Kick:
A tune up is what's needed. Make sure your timing and valve clearances are all good to start with or skip that bit (but better to check first :wink: ) then as E.Marquez says + the TPS adjustment helps alleviate it.
These are the biggest carbs you will find on a production bike and are sensitive to small changes!! Things like carb balancing make a difference. You may want to fit a front vaccum take off for ease of carb syncing.
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18430
I don't . The only time I tuned to cough out was when I fitted standard carbs and cans .
Explain yourself young man. :lol: :Ball Kick: (:-})
From what I've read and done there's many old wife's tales on how to get not to do it .
Some work some don't even with the carbs set up perfect it still did it now and then .
Yes cleaning balancing the carbs and setting the tps helps as dose a full service but it will still happen now and then .
If you've managed to stop it from doing it great
Or I'm just talking nonsense again :wink:
Virt
Post by Virt »
lloydie wrote: Or I'm just talking nonsense again :wink:
"Again"? When did you stop? :wink:
:Lol: I have a condition /-(
Virt
Post by Virt »
Living in Cov?
Virt wrote:Living in Cov?
It's not helping !
