Ey up fellas,
My newly rebuilt forks are back in the yokes, would you put them back as standard or is there any advantage in moving them up in the yokes a bit to improve the steering?
Forks - Refitting
Forks - Refitting
Re: Forks - Refitting
Mine is up about 7mm seams ok but was done by previous owner so don't no how standard handles like.
"It may be yellow but it ain't no chicken"
If you've had Roger Ditchfield breath on them, I found a starting point of 5mm more of the fork stanchions sticking up above the top yoke a good balance.
Excellent, thanks Magnum and Chris - I'll go middle for diddle and do 6mm....
Hey Mav, Roger Ditchfield recommends 5mm for road bikes and 8mm for race bikes. I went 4mm and it has made a very positive change.
Livened up the handling a treat and remains very stable.
Jamie
I'd recommend no drop if you have the 6mm shock spacer fitted, to start with, then try 2mm at a time as you get used to them.
It can all get a bit slappy WOT leant over if the road isn't smooth (over cat's eyes, for example.
Good advice, thanks guys. I have the 6mm spacer but not fitted yet as can't get the back end off the floor (Abba stand mod not done yet).
When did you do that ??Jamoi wrote:Hey Mav, Roger Ditchfield recommends 5mm for road bikes and 8mm for race bikes. I went 4mm and it has made a very positive change.
