Fully adjustable black levers £10
Moderator: VTRDark
Fully adjustable shorty levers, cnc machined and finished in black.
They are not a brand name, they are cheapo ebay jobbies, they were around £40 iirc.
These have been on my bike for around 500 miles this year, despite them being cheapo levers I have been impressed with the look and feel of them.
I would STRONGLY recommend going over them with a careful eye, perhaps loctite the nuts. Before you use them. I do worry about these things.
Be quick! Yours for £10 via paypal posted
Jamie
Re: Fully adjustable black levers £10
I'll have em!
Wicky make sure you have a gap between the lever and the piston .Wicky wrote:I'll have em!
Or risk warping you discs .
I'm sure Jamio would have checked but it's worth checking when you fit them
I'll check the fitment compared to standard - don't they sometimes need the bushings sorted for a good action?
lloydie wrote:Wicky make sure you have a gap between the lever and the piston .Wicky wrote:I'll have em!
Yeah, do this. I lost a good set of Armstrong discs thanks to my brother.lloydie wrote: Wicky make sure you have a gap between the lever and the piston .
Bushing normally good it's the clearance they suffer with .
And give them the slap test on all settings
I'll have the Baywatch babes please Jamie , how much
- bigtwinthing
Watty wrote:I'll have the Baywatch babes please Jamie , how much
I've already had them!!! ( i wish)
bigtwinthing wrote:Watty wrote:I'll have the Baywatch babes please Jamie , how much
I want to give the baywatch babes the "slap test" !!
Wicky, if you like you are welcome to pop over on Sunday and we can make sure they function properly on your bike. Or I can ride over to you.
They are similar to my titax levers with regard to fit and feel. The titax feel like they have slightly tighter tolerances in the machining process, I.e no play at all.
If you don't like them, then you're not committed to buy them
Jamie
Jamoi if wicky don't want them you can ride to mine and try them on my bike
"It may be yellow but it ain't no chicken"
