which reg/rec to buy?
scoobie_sore_paws
Post by scoobie_sore_paws »
OK so looks like I might need to replace the RR but with which one? Loads on eBay that range from 18 to 56 that to me look the same but no clue on them. Is there a recommended site or seller or type?
Re: which reg/rec to buy?
Mosfet type are the way to go but will cost more.
Cbr125 is straight plug & play.
R1/R6 finned type will work but you need to sort the plug out to fit.
Try searching in the workshop section for threads on the subject.
budd
Post by budd »
+1 CBR 125 sorted mine out last year :thumbup:
Storm is now gone :cry: .
scoobie_sore_paws
Great thx guys will do that. How do I check voltage on existing one? Just with multimeter?
Sorry total noob with electrics
scoobie_sore_paws
MacV2 wrote:Mosfet type are the way to go but will cost more.
Will do ta
Jscobey
Post by Jscobey »
i wouldnt get the CBR125 unit because its still a crappy shunt based unit which will eventually fail just the storms OEM unit. the shunt based units run REALLLYYYYY hot and eventually burn themselves out.
what you really want is a MOSFET R/R. i just installed one last week. all thats involved is cutting the current plug that goes into the RR off, and either putting on spade connectors, or you can buy the actual connectors from easternbeaver.com
the crappy shunt based units have an "SH" stamped on them.
the much much better MOSFET units have an "FH" on them. i got mine from a 2007 ZX-14R but there are lots off different mosfet units you can use. theres a list of the compatible ones on post number 6 http://www.superhawkforum.com/forums/kn ... how-25117/
this is a crappy shunt based unit
and this is a MOSFET
mattycoops43
Post by mattycoops43 »
I got this one, dead easy to fit, and works great. it's meant to shut down if it overheats and then just start working again when it cools off.
http://www.ebay.co.uk/itm/380704480069? ... 1497.l2649
Jscobey
Post by Jscobey »
Perfect!
mattycoops43
It's a lot bigger then the original, but it just fits inside the seat unit without touching the plastics. Attached with the top bolt only as it needs to sit in line with the subframe and the spacing is different anyway. It is so big and finned, it doesn't rely on the metal to metal with the seat frame to lose heat like the original ones did anyway so it's fine.
Jscobey
Post by Jscobey »
The one I have is pretty large too. Prolly about the same size, only attaching at the top bolt. Just barley fits inside but that's a lot more surface area for cooling. I used spade connectors for now but I'm gonna get a set of actual connectors from eastern beaver so everything is kosher.
lumpyv
Post by lumpyv »
budd wrote:+1 CBR 125 sorted mine out last year :thumbup:
+1 me too
Agree but an R1, CBR or equivalent non MOSFET type is a step up, or should I say, step in the right direction from the original non finned VTR one. It depends on how much one wants to spend.
Jscobey
Post by Jscobey »
i couldnt agree more! anything is better than the unfinned stocker.
although my mosfet ZX14 R/R was like $40 USD and the non mosfet "upgrades" you speak of arnt much cheaper so really if you just look for a week or two youll find a good deal on a great unit. mine was used but looked BRAND new.
really happy with it. but yes almost anything = better than OEM unit.
tattoo
Post by tattoo »
+1 on the honda cbr/xl 125 r/r...i've had one fitted 2yrs now and hasn't given any trouble at all
scoobie_sore_paws
tattoo wrote:+1 on the honda cbr/xl 125 r/r...i've had one fitted 2yrs now and hasn't given any trouble at all
Any model or year? Is a finned one I have just now not sure of number tho but not the standard
