2 short stack/bellmouth questions
ive been reading on here that changing to 2 long stacks gives you more low end oomph, and 2 shorter stacks gives you more top end.
when i did my MCCT install the other day, i found out that the previous owner used permanent loctite on the mounting bolts for the rear stack so in trying to remove the stack it destroyed the threads on the airbox. long story short since the threads for the stacks are part of the airbox itself, i had to buy another airbox for about $20 on ebay. it comes with everything including new stacks.
im thinking about playing around with the stacks and possibly trying 2 short stacks for more top end.
just looking for experience from anyone who's done this. what was the outcome? what was done to the jetting? how much top end is gained? is it a worthy sacrifice in bottom end?
i read that honda put in one long and one short stack so that low/mid range one cylinder is working harder, and at top end, the other cylinder takes over.
- bigtwinthing
Re: 2 short stack/bellmouth questions
too much top loses you your licence!!!! does that help!!! 150 is fast enough!!!Jscobey wrote:ive been reading on here that changing to 2 long stacks gives you more low end oomph, and 2 shorter stacks gives you more top end.
Not interested in top end but the faster you get there is more fun ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
I run 2 short stacks, have done for a long time now. tried 2 long but preferred the feel of the 2 short.
I have 15/44 gearing so need the engine to run up a little higher from time to time.
when I had it dyno'd on rogers dyno a few years back after having the jets changed 2 short and a K+N the curve was lovely and flat with the big dip gone. hopefully get the lightened flywheel back soon so see how that goes as well .
Max
![Image](http://i27.photobucket.com/albums/c156/wjames/babies2.jpg)
It's not about going over 150mph. It's about more top end in each gear. I'm jut wondering what the consensus is by people who have tried it.
also is it more beneficial to have actual velocity stacks?
the only aftermarket stacks i can find are the H Power stacks from OZ but one is the length of the long OEM stack, and the other is longer than that so a 2.5hp gain in the midrange but im looking to go to 2 shorter stacks.
is there anywhere that sells 2 short aftermarket velocity stacks?
Dr Honda, A&L in the US?
No unless you buy two sets of moriwaki and use just the short ones . Tho they sit flush to the airbox floor and might be to much
Irrelevant to conversation but can I have first dibs on the extra long stack, if you do decide to go 2 shorts? Cheers ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
And these are mine ![Image](http://img.tapatalk.com/d/14/03/26/4umynu9a.jpg)
the A&L link says they are out of stock. i saw that website a few days ago but it seems like its out of stock and prolly will never be in stock again
lloydie it seems like the shorter one is VERY short and the long one is like the shorter stock one.
that is a setup i like!
what's the internal diameter of the OE stack ? these are available from Rally Designs in various lengths
http://www.rallydesign.co.uk/product_in ... ts_id=3339
I've now gone all European and bought a KTM Superduke GT and Aprilia RSV1000R
Storm is now gone
Storm is now gone
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
my next thought was if any other bike has a similar stack size that could workbudd wrote:what's the internal diameter of the OE stack ? these are available from Rally Designs in various lengths
I think the problem is that the VTR carbs are massive compared to most other bikes or indeed cars, I have mate with a V8 Capri that is on quad 50mm down draft dellortos, he's always messing about with different air-filters, air-boxes maybe he as some 50mm trumpets laying about, it's definitely worth a visit to see, plus he's just bought a Lambo Aventador so I can have butchers at that at the same time.
Storm is now gone
Storm is now gone
