954 fork recall !
954 fork recall !
Don't know if you guys know this but honda did a recall on the 954 for a few things .
One being the forks !
It's the fork lowers that crack when the lower pinch bolts are tightened up so honda did a recall to replace them .
Might be something to look at next time your with your precious
Re: 954 fork recall !
Good shout Lloyd :thumbup: Is that for all years? This should be linked up with the fork upgrade threads as it's a safety thing.
All 954 years
929's as well. Honda sent out recall letter on 14th Feb 2006 - It states model year 2000, 2001, 2002 and 2003.
They replace the cast lower and the chrome stanchion as one lump.
Forks out, strip down, replace stanchion and lower casting. Rebuild using your original inners and upper tubes. If you ask them nicely they give you fresh oil. Re-fit forks. Takes about three hours.
Problem is IDing which ones they've done as Honda probably did it by frame no. Tricky if they've been transplanted...
I mentioned the recall in Tonys thread when he was trying to get the lower castings of the tubes.
Now repeat after me... I must pay more attention in class.. I must pay more attention in class... I must... etc
Definitely worth bringing this subject up again though and making a sticky
:D
yup I already knew this, its another risk when buying second hand cbr929/954 forks, you have to assume that blade owners got them changed, i'd assume most would have knowing the seriousness of the problem. it always good to give them a visual check tho.... :thumbup:
Jamoi wrote:I mentioned the recall in Tonys thread when he was trying to get the lower castings of the tubes.
:D
My bad :lol: I was to busy looking at the pic of your ... :-)
Hehehe git :lol:
There was recalls on our bikes too with the fuel tap diaphragm.
http://www.vtr1000.org/phpBB3/viewtopic ... 015#p91370
Maybe this should be added to that thread and the thread re-named Honda Recalls or Bike Part Recalls or something and stickied. It keeps everything in one place then and easy to find. :think:
Strangely though I have noticed a lot of forks on eBay are damaged in that area, but always assumed they where crash damaged.
most if not all will be crash damaged, they are blade forks after all, if the forks had been taken to Honda for the recall, they would have been humanely disposed of by honda.... :lol:
alexmac
Post by alexmac »
only effected a very small number world wide iirc.
had mine changed 2007 and the guy at branson honda told me that
the only 954's so far effected were in canada and north america.
he said HRC thought the problem was caused by condensation getting in between the
lower fork stanstion and axle casting (freezing, expanding and cracking the casting
round the top.)
he also said that all effected 954's had been subjected to sub zero temperature's.
probably left out door's overnight. and that their had not been a case (so far) of any bike's
affected in the uk or western europe.
i tried my hardest to buy them back. was looking for some for thre VTR at the time.thought i was on a winner NO WAY. told they were all being destroyed.
perfectly good pair of fork leg's. what a SHAME. whatever happened to commom sense??????
atb alexmac
alexmac wrote: he also said that all effected 954's had been subjected to sub zero temperature's.
atb alexmac
Mmmmm. It does get down to below freezing here, too.
Wonder why they haven't caused a problem here?
Especially with the wind chill at 100mph :fart1: :eek2
alexmac
Post by alexmac »
i don't know? it's just what the man said.
maybe just bullshit,covering up for something else'
had mine since 2002 no problem's with the fork's
fireblade,forum member and never heard of this problem in the uk.
atb alexmac
