Rear Axle
- carmanbikes
Rear Axle
anyone know how long the rear axle is and also how long the swinging arm axle is, Thanks
Re: Rear Axle
I'll measure when I get home as I have a spare of both. The rear axle is I think the shorter of the two. I believe the swing arm pivot bolt is longer
- carmanbikes
Re: Rear Axle
ThanksJscobey wrote:I'll measure when I get home as I have a spare of both. The rear axle is I think the shorter of the two. I believe the swing arm pivot bolt is longer
Re: Rear Axle
Right you are, as g_l_s_r (mark) noted when he made his custom one-off axle adjusters...... IIRC, the pivot is @ 10mm longerJscobey wrote:I'll measure when I get home as I have a spare of both. The rear axle is I think the shorter of the two. I believe the swing arm pivot bolt is longer
Re: Rear Axle
swing arm pivot bolt is just shy of 14 inches, rear axle is around 13 inches
- agentpineapple
