Reference - Linkage Bearing, Seal Sizes and Part Number
kitsun
Post by kitsun »
For the complete replacement of the suspension linkage needle bearings and seals you need:-
4 needle bearings Honda part number 91072-KT7-003 item number 17 of size 17x24x20
1 needle bearing Honda part number 91071-KV3-005 item number 20 and of size 17x24x25
6 dust seals Honda part number 91262-KV3-831 item number 19 and of size 17X24X5
If you do the rear shock as well then you need to add
2 dust seals Honda part number 91262-KV3-831 item number 19 and of size 17X24X5
kit
Re: Reference - Linkage Bearing, Seal Sizes and Part Number
Can we transfer this to the knowledgebase, please?
Well done, Kitsun, good find.
thunderbolt
Post by thunderbolt »
Kit, which microfiche did you use to reference the item numbers, e.g. 17, 19, 20, etc.
The fiche I am using (diagram) has some different numbering on it than the ones you have quoted.
Can you put up a link of the fiche you used please?
Thanks
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
You have to watch those microfiche's as sometimes the part numbers they have are their own numbers and not genuine Honda part numbers. Good catch thunderbolt. :clap:
kitsun
Post by kitsun »
References mostly from US sites
http://www.ronayers.com/REAR-SHOCK-ABSO ... 75558.aspx
And from Partzilla ( which I've bought from)
http://www.partzilla.com/parts/search/H ... parts.html
Kit
thunderbolt
cybercarl wrote:You have to watch those microfiche's as sometimes the part numbers they have are their own numbers and not genuine Honda part numbers. Good catch thunderbolt. :clap:
Carl it wasn't that the Part#s were different it was the numbers on the diagram for each individual part. Can be bit of a trap.
Don
Bikes:
1990 Suzuki VX800
thunderbolt
kitsun wrote:References mostly from US sites
Kit
Thanks Kit,
What was your experience like with Partzilla? What was delivery time like?
Thanks
Don
Bikes:
1990 Suzuki VX800
thunderbolt
Kit, you had the oil/dust seal on your reference file above as number 19 on the diagram, but No. 19 on both Ron Ayers and Partzilla is a dowel.
Don
Bikes:
1990 Suzuki VX800
kitsun
Post by kitsun »
Partzilla is fine except that shipping is based on cost I.e usd40 shipping cost for anything purchased up to usd100 after which it goes up. Parts can take sometime to arrive as they have to order parts from American Honda. I use only as a last resort when I can't get parts elsewhere.
Kit
kitsun
Post by kitsun »
thunderbolt wrote:Kit, you had the oil/dust seal on your reference file above as number 19 on the diagram, but No. 19 on both Ron Ayers and Partzilla is a dowel.
I'm a cockeyed sod!!
thunderbolt
No Problem Kit
Don
Bikes:
1990 Suzuki VX800
TravisZack
Post by TravisZack »
Thanks for the list, very useful!
I found these guys to have good prices and got them next day on the standard delivery :thumbup:
http://shop.marksman-ind.com
