Renntec mounts
Renntec mounts
Could any of you guys please tell me, the bracket that runs across the subframe, do the threaded lugs go above or below the rear mounts for the tail plastics? Cheers, Watty.
Re: Renntec mounts
Below
Re: Renntec mounts
Cheers Lloydie, so then the rear fixings for the tail plastics go through their original fixings and also pick up the thread on the Renntec mount?
Re: Renntec mounts
Yes you got it
Re: Renntec mounts
You are at the moment but trying very hard to get to the top. Is this what is known as a false start.lloydie wrote:Below
Re: Renntec mounts
Could be worth fabricating additional angle brackets. I only carry an old rectangular tank bag on mine and my mate who always follows, says it shook up and down a lot. I used 4mm steel and as it would be fiddly with nuts, put a thread in. Will try to get pictures.
Theres A Hare in The Turnips.
