I have just become the proud owner of a standard '99 Firestorm and i have a few questions.Be gentle with me!
Can you adjust the biting point of the clutch as its at the end of the lever travel ?
Any reccomendations for braided steel hoses for the front brakes ?
When i fit aftermarket exhausts do ineed to re-jet?
Exactly how bad is the fuel consumption !
Thanks in antipitation.
A few questions ?
questions
Eyup,
Clutch - don't know
Braided hoses - try new brake fluid first, it works wonders!
Exhaust - I didn't re-jet for my Remus and it didn't make any difference
Fuel consumption -
if you haven't got a shell plus points card, go and get one NOW!!!!! (16 litre tank, average 90 miles to light)
Welcome and enjoy the site
Dave.
Clutch - don't know
Fuel consumption -
Dave.
Take it to bits, put back together, nothing left in box...woohoo!
You can adjust the clutch, or so I believe. I haven't seen mybike in a bit over a wk. some git decided to stop acros my lqne and well i kinda had a little coming together with him. the lesson to be learned from this is dont ride in shorts and a tshirt. but the clutch adjustment should be like the one on the front brake. Simply have a little play wth it and set to your desired position. there is also a bleed nipple down by the casing. use it. just like bleeding brakes. nothing like fresh fluid.
I to have a 99 storm and i recommend getting the carby's jetted. a k&n or bmc air filter wouldn't go astray either. trust me on this one i now get around 190k's before the light comes on as opposed to 120.
have fun and stay shiny side up mate...
- blackstorm
