Hi all
Phil_H
Hi all
Post by Phil_H »
I have just signed up here, so thought I better pop in and say hi :)
Here by default really so don't slate me....
I'm the new to me owner of a 2000 model Varadero, carb'd version and feel the motor is not quite as sweet as it should be - searching for cct info led me here, where you guys seem to have much more info & solutions (and problems??) on the subject than in Varadero land!
Phil
sent from my 'phone
Re: Hi all
The motor is mostly the same, later Vara's are Fi, and earlier ones had only a 5 spd box, I believe, but everything's swappable, inc pistons and cams, so you can really get a performance upgrade with fitting Storm bits.
Re: Hi all
Hello and welcome
Re: Hi all
Cams would be an easy swap too. :thumbup:
Some links regarding the Cam Chain Tensioners (CCT's)
You can either go for the stop mod http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=19416
Which is the Honda auto CCT's that are converted to a fail safe. So when it does fail, it don't send the valves crashing.
Or
You go for the full manual conversion, your options are here
http://www.vtr1000.org/phpBB3/viewtopic ... 16&t=22720
Then with regards to fitting View Topic
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=28583
Welcome to the forum. :beer:
Re: Hi all
welcome to the forum phil, stick around we are a friendly bunch, if not a little stupid at times.... :wink:
macdee
Re: Hi all
Post by macdee »
hello and welcome
wouldn't mind having a varadero sometime :thumbup:
Phil_H
Re: Hi all
Post by Phil_H »
Thanks for the welcome all, much appreciated :)
I think I'm currently all cct'd out.
What with stopper mods, replacement springs (are replacements still available??), Manual cct's and the bolt in the rear which I don't quite fuly understand for some reason - it's all a bit bewildering!
I like the idea of keeping the stock honda adjusters but with somekind of homemade failsafe fitted (plus I'm a skinflint lol)
Phil
sent from my 'phone
Re: Hi all
Welcome to the club Phil :thumbup:
Shauned71
Re: Hi all
Post by Shauned71 »
Hello :wave: welcome to the forums :)
Re: Hi all
Hello and welcome :thumbup:
Ckennedy
Re: Hi all
Post by Ckennedy »
Welcome to the club :thumbup:
Sent from my HTC One using Tapatalk
Re: Hi all
Try reading that again. You don't replace the springs.
Stop mod is perfect fpr you then, that's what you want.
Phil_H
Re: Hi all
Post by Phil_H »
What a pleasant welcome, thank you :)
I think you've misinterpreted my post, maybe I never wrote it clearly.
I understand the spring remains with the stopper mod, I had read somewhere of people renewing the springs as routine maintenance rather than removing it when doing the stopper mod.
It's all a lot to take in but there is lots of info here :)
Can someone explain the mod with longer bolt in the rear of the cct?
Phil
sent from my 'phone
macdee
Re: Hi all
Post by macdee »
The mod with the bolt out the rear of the cct is a mcct mod
On the stopper mod you will not see any difference in appearance
Look up the workshop section for the stopper mod
Re: Hi all
Phil_H wrote: I think you've misinterpreted my post, maybe I never wrote it clearly.
Phil
sent from my 'phone
Welcome aboard Phil :thumbup:
You have been a busy boy reading up on the CCT options, I'm impressed :clap:
First of all, yes you're right there was a member on here who could supply replacement CCT springs. The problem seemed to be that buyers found it difficult to work out how much pre-tension was needed when installing new springs into an old CCT. So replacement springs didn't really take off.
Putting a longer 6mm bolt in the rear of the CCT (I'm assuming you came across that in your reading-up on here), I can explain how that works (but I don't have the time right now), but basically you are turning the standard CCT into a manual cam chain tensioner. Let me know if you would like more on that, unless someone else explains it of course :)
