Found a screw
Found a screw
Found this screw on the floor in the bike shed this morning, can't find anywhere obvious where it has come from. It's 20mm long and 4mm thread, it's the same as the one that locks the cap in the clutch fluid reservoir only shorter.
I've done a few jobs recently including stopper mod on the ccts, fitted braided brake hoses and new fluids all around.
Any ideas?
Any ideas?
Re: Found a screw
Re: Found a screw
That looks very much like one of the screws that holds the airbox to the carbs.
Re: Found a screw
May be from your switch gear as mine worked loose once
Found a screw
+1 brake light or clutch switchDuffy1964 wrote:May be from your switch gear as mine worked loose once
Re: Found a screw
Switchgear, as said already.
The black paint gives it away.
There are similar sized ones in several places, but only switchgear ones are painted.
Re: Found a screw
less weight so it will go faster.
sorry in get my coat
Re: Found a screw
cant see anything obvious, I'll take the fairing off in the week to check properly.
certainly went fast enough earlier (even if it is teal)
Re: Found a screw
did it see a reflection of itself then.certainly went fast enough earlier (even if it is teal)
Re: Found a screw
Ha bloody ha Carlcybercarl wrote:did it see a reflection of itself then.certainly went fast enough earlier (even if it is teal)
Re: Found a screw
Nice one Carlos
- agentpineapple
Re: Found a screw
