Somthing Missing
carmanbikes
Somthing Missing
Post by carmanbikes »
I think I have a part missing does anyone know what it is I have looked on the fische and it says the hole should have a trim clip in it but cant see why I know the rad grille is missing but cant see how it would go to that
Re: Somthing Missing
have you got the two brackets that go under the rads, one each side, then i normally use small cable ties to attach them to the Little hole in each fairing, it will mean that everytime you take the fairings off, you'd need to snip the cable ties, imho it just strengthens the front fairings.... :thumbup:
http://www.ronayers.com/RADIATOR-C212290.aspx
numbers 18/19
carmanbikes
agentpineapple wrote:have you got the two brackets that go under the rads, one each side, then i normally use small cable ties to attach them to the Little hole in each fairing, it will mean that everytime you take the fairings off, you'd need to snip the cable ties, imho it just strengthens the front fairings.... :thumbup:
numbers 18/19
Hi Martin, Is this the brackets just found them in another box
that's them mate.... :thumbup:
carmanbikes
agentpineapple wrote:that's them mate.... :thumbup:
Sorted, Thanks mate :thumbup:
