seat damaging tank
macdee
seat damaging tank
Post by macdee »
so the seat is damaging to tank its rubbing the folded edge removing paint and causing rust
whats the best thing to do to stop this, cut the seat ,rubber edging ??
anyone got the same problem
thanks
Re: seat damaging tank
macdee wrote:so the seat is damaging to tank its rubbing the folded edge removing paint and causing rust
thanks
Should be rubber edge protection on there mate if it's where I'm thinking of :?
macdee
Post by macdee »
edging is gone but the hard plastic inside the seat is cutting into the tank and will probably cut the rubber as well
does the seat rub your tank or is there a gap :thumbup:
macdee wrote:edging is gone but the hard plastic inside the seat is cutting into the tank and will probably cut the rubber as well
My seat does pretty much touch the tank but not to the point of rubbing paint off :? . Post up some pics mate :thumbup:
You can bend the securing loops a little rearwards to reduce the forward pressure onto the tank. Makes it easier to remove the seat, too..
Or put some clear protective tape on the tank to protect it.
macdee
Post by macdee »
thanks for the input men
i will carry out the said improvements :thumbup:
AMCQ46 wrote:Or put some clear protective tape on the tank to protect it.
beat me to it.... :thumbup:
Angle grinder to shave a few mm off either seat or tank...
macdee
Post by macdee »
Wicky wrote:Angle grinder to shave a few mm off either seat or tank...
are you mad 8O
Bloody hell Wicky are you a plant fitter 8O
Make sure the tank is empty of course and always wear eye protection.
macdee
Post by macdee »
i have turned on the electric fence
doubled up on the guards
and set the lazer from stun to kill :Gun3:
