just want to check that this is the front sparkplug drain hole, the one that can get clogged up with road crap?
whats best to clean it out, wd40 with the red straw maybe, as I don't have an air line.
front plug drain hole
- agentpineapple
Re: front plug drain hole
thats not it\
the one you want is in the head just under the exhaust port casting
- agentpineapple
have you got a picture Al?AMCQ46 wrote:thats not it\
or could you point out on my picture where it would be, I assume then its hidden behind the exhaust port in my pics?
It's there
- agentpineapple
cheers lloydie, i'll have a good look in the morning....
Shine a torch down the spark plug after removing the plug cap and you will see the light.... Praise Be! (goes off down the pub, singing, clapping and dancing in tongues.....)
- agentpineapple
found it, in case anyone wants to know, here's the drain hole for the front spark plug, make sure its not blocked, because if you ride in rain, it can get blocked and you'll end up on one cylinder....
Or on a dyno, with a fag paper plug cap......agentpineapple wrote:found it, in case anyone wants to know, here's the drain hole for the front spark plug, make sure its not blocked, because if you ride in rain, it can get blocked and you'll end up on one cylinder....
Loving the Blue even more Marty
