Operation chinese
Redthunder
Operation chinese
Post by Redthunder »
Temporary Chinese fairing arrived this morning...
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Destined4bikes17@gmail.com
Re: Operation chinese
let us know how you get on with the fit and finish of it......... :thumbup:
a friend of mine had Chinese fairings on his gixer, unless you had a right good inspection, you couldn't tell.....
Redthunder
The red doesnt match the original tank. Paint not awful of the odd run at the edges. Fit isn't too bad although having to open up the headlight hole a little.
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
bald_pig
Post by bald_pig »
if you can find a set in orange, let me know, seems to be impossible to get!
bald_pig wrote:if you can find a set in orange, let me know, seems to be impossible to get!
The ones on e bay will paint any colour you like.
Redthunder
Photo bucket down :-\
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Redthunder
Fitment so far...
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
looks good to me mate.... :thumbup:
Redthunder
One issue.. where the headlamp has four screws which should screw into 4 captive nuts cast into the headlamp cowl, the lower 2 were cast vertically instead of horizontally. So useless.
Whilst fairing is on and tight the 2 plastic alignment clips don't locate tightly. Have had to shave a little off each side of the headlamp.
It was never going to be as good as originals but not bad for £300 odd quid.
Just the tail light left to do now.
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
They look pretty good to me in the photo's :thumbup:
NZSpokes
Post by NZSpokes »
Can you buy just the tail piece? Mine is a bit cracked.
Jscobey
Post by Jscobey »
What swing arm brace is that?
Redthunder
Jscobey wrote:What swing arm brace is that?
Bespoke on vtr swingarm
:-D
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Redthunder
NZSpokes wrote:Can you buy just the tail piece? Mine is a bit cracked.
Maybe but given the risk of the paint not matching the rest of your bike, I'd suggest get your original plastic welded.
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
NZSpokes
Post by NZSpokes »
Probably be repainting the lot in one go anyway. I dont know much about plastic welding and if it is a permanent fix.
