Alternator cover inspection hole screw
Moderator: VTRDark
Being on the very cutting edge of excellence I didn't tighten up the inspection bolt/screw that covers the smaller of the two holes in the alternator cover properly last time I took it off.
I went out for a bit of a blast last night and it has now parted company with the bike
Anybody got one I can give them some beer tokens for? Haven't found them online but then again my description of the part isn't exactly accurate
Re: Alternator cover inspection hole screw
The part you're looking for below is Number 9. If you didn't know, you can click the image below to enlarge it,
You, sir, are a gentleman!
If you havn't ordered one already, I've got one you can have. Just pm my your address.
- agentpineapple
I also have a spare one mate, let me know if you need it.....
- bigtwinthing
Jamies glove may have it!!!
Check your oil level too as you may have lost some in spray out of the inspection hole without it being capped off
Thanks gents!
pm on it's way to Mr Pineapple. Hopefully this won't turn out like the also time I bought stuff from you. So many shiny things that I suddenly needed
Will do Carl. It is coming out in a fair spray as obviously I haven't stopped using the bike
You can do the small one up fine- it's the big one that you daren't tighten, and needs to be held in with silicon sealer.
My advice is to use an Allen key- use the smaller section to tighten it, and the longer section to undo. Hasn't failed me yet!
- agentpineapple
luckily for you I was away.......Geoff S wrote:Thanks gents!
as I have a few items you might be interested in.....
